AEM EMS Get tuning help for your AEM EMS system.
AEM Serial Gauge Users Please Chime in!!!
Old Sep 28, 2008 | 10:04 AM
Boost3dxEvO's Avatar
Question AEM Serial Gauge Users Please Chime in!!!
I am going to an AEM with built in wideband.. I am wondering if the Serial Gauge will read the wideband readings?
Also, with a 5 bar map sensor installed.. Will I be able to see 30+psi on the Serial Gauge? Also, does the serial gauge monitor your vacuum, just like a regular boost gauge would?
I don't have any gauges and I'm considering just buying 1-2 of these Serial Gauges and calling it a day.. Please let me know your experiences with it. I would greatly appreciate it!!
Here is the channel serial gauge I am referring to:
http://www.vividracing.com/catalog/a...e-p-19053.html
Old Sep 28, 2008 | 07:34 PM
Any body? I am also looking at buying 2-3 of these and linking them together like it says.. any one have luck with this?
Old Sep 29, 2008 | 09:04 AM
bump for answers please!
Old Sep 29, 2008 | 07:07 PM
omniprobe's Avatar
try asking in the aem forums
Old Sep 29, 2008 | 07:10 PM
thanks
Old Oct 1, 2008 | 08:29 AM
loppad's Avatar
Not sure, the AEM built in wideband ECU doesn´t have the O2 sensor feedback signal pin.
Also, the AEM gauge takes the O2 wideband signal first and gives the reading (in AFR, lambda, etc) then take it to the ECU O2 feedback signal pin. Actually the AEM gauge also has a heating circuit for the O2 sensor.
loppad
Old Oct 3, 2008 | 02:54 PM
EVO8_PR's Avatar
Yes the Serial Gauge will work perfectly. You can monitor the a/f ratios, vacuum(in -psi) and boost, etc.
