AEM EMS Get tuning help for your AEM EMS system.
Battery dead? Do you need to sync again?
Old Oct 24, 2008 | 10:47 AM
omniprobe's Avatar
I was reading how if your battery dies, aem needs to be synced again.
Old Oct 24, 2008 | 12:43 PM
GTVEVO's Avatar
Not that I have ever known, can you stick this information in the thread here to ensure you aren't being misinformed some how?
Old Oct 25, 2008 | 07:19 AM
Spaceball 1's Avatar
Wow i pull the battery all the time and never sync. Post up that info...
Old Oct 25, 2008 | 08:59 PM
Kmac's Avatar
The AEM does not loose its memory if the battery is disconnected. My car sat without a battery or a motor in it for 2 months and it fired right up after it was put back together
Old Oct 29, 2008 | 02:04 PM
blacksaleen95's Avatar
assuming you are talking about ign sync then no it will stay in the ecu without power.
When you go to ECU-setup-ign all you're doing is changing the ign sycn value under
ign-ign phasing-options-ign sync
that value is your sync value...should you change cal files to an old one or something else just copy/paste that value (assuming nothing mechanically has changed) and you will be sync'd
