AEM EMS Get tuning help for your AEM EMS system.
Lean at cold, rich at hot..!!!??
Old May 28, 2009 | 01:51 PM
El Boricua's Avatar
Question Lean at cold, rich at hot..!!!??
Hey,
Can someone please tell me why my car is lean when it start in the morning, and then until I drove it around it gets richer and richer...?
Did I have something set the wrong way..? I don't know..!! maybe the idle invert or something..?
Please help..!!
Thanks,
Old May 30, 2009 | 02:17 PM
TheBoz's Avatar
- Fuel
--> <<Advanced Fuel>>
----> Fuel Trims
------> Air Temp Fuel Corr Table
You whole map is more than likely set at 0. So what you are going to need to do is modify that table, and add fuel when it is cold, and remove fuel when it gets hot.
So as you are driving around in cold weather try to adjust that table and get your AFR's to match where you were tuned at.
Here is a SAMPLE of what I am using, which for me is still off on pump gas and race gas, I have not fully tweaked it.
34.375 28.90625 23.828125 19.140625 14.453125 10.546875 6.640625 3.125 0 -3.125 -5.859375 -8.59375 -11.328125 -13.671875 -16.015625 -18.359375 -20.3125
-40 Degrees --------------------------[104 degrees]---------------------------> 248 degrees
Use at your own risk.
I took this from the Boost Comp Excel sheet on aempower forums.
Old May 30, 2009 | 02:44 PM
EVO8_PR's Avatar
Originally Posted by TheBoz
- Fuel
----> Fuel Trims
while this is true in many places, here in Puerto Rico your starting air temps could be in the high 80's when initially starting your car, and rise to about 95-100 when driving. What you should check is what cell of the fuel map is highlighted when cold(coolant temp) and compare it's value with the one highlighted when @ normal operating tempertaure.
BTW, let me know when you get your fuel assembly.
Old May 31, 2009 | 02:10 PM
El Boricua's Avatar
Thanks for the tip....!!!
YES I will...!!
Thanks,
Old May 31, 2009 | 06:14 PM
El Boricua's Avatar
WOW... great... did that, plus did little adjustments at the Warm Up Enrich table, the Start Decay, and the Start Extra table, and after two days of not using the car, it started the first try... and it went very smooth while warming up..!!
Once again thanks..!!
v8<turbo4
Jun 9, 2014 08:44 AM
stunt2
Jun 24, 2013 01:24 AM
xhomm02
Aug 25, 2009 11:15 PM
silverstream
Jan 31, 2009 08:58 AM
house_of_senate
Oct 3, 2008 09:24 AM
