AEM EMS Get tuning help for your AEM EMS system.
Knock??
Old Jun 28, 2009 | 08:53 PM
evodrivesme's Avatar
Knock??
So I had my car tuned by a friend today after we installed the boost controller and we were picking up knock. It was always a max of 4 volts which is a lot but its not actually knocking we dont think. no signs of detonation nothing.. the car runs like a champ.. amazingly actually. i forget what he said but we did it with something turned off and something turned on that had to do with the knock sensor, anyways it would reach a max of 4 both times. any ideas of what could be going on??
noise from something else.. maybe a grounding problem.. bad sensor??? im lost
thanks
Old Jun 28, 2009 | 09:09 PM
heel2toe's Avatar
I have heard that if your downpipe rattles your transfer case the knock sensor could pick it up thinking its knock.
Old Jun 29, 2009 | 04:33 AM
ya i would believe that, my car is sooooo damn loud.
Old Jun 29, 2009 | 04:43 PM
1badmr's Avatar
mine does the same thing so we just unhooked the knock sensor when we tuned i might add though i have a very conservative tune 18 psi on 93 and denatured alky
Old Jul 2, 2009 | 05:49 AM
althemean's Avatar
If you do not calibrate the knock sensor and you tune without it things will be fine. Problem will be when you reactivate it and the sensor sees false knock (normal engine noise) and starts adding fuel and taking timing out.
