AEM EMS Get tuning help for your AEM EMS system.
Exporting AEM Logs to Virtual Dyno Room
Old Jun 8, 2010 | 11:37 PM
BillSpec's Avatar
Great work! Thanks Boz!
Old Jun 10, 2010 | 02:37 PM
red03evo's Avatar
Got it to work now.
Thanks guys!
Old Jun 20, 2010 | 09:10 AM
Jack_of_Trades's Avatar
Just letting you guys know, we are working on VDR v6.00 and it should automatically work with exported AEM logs without any copying/pasting. So it sounds like I should be recommending AEM users to log in 'PC logging' mode to work with VDR? How many lines has anyone seen in this mode during a 4th gear pull? VDR v6.00 was limited to only 600 lines of code but I can increase it if I need to.
If someone could PM me and send me an exported AEM .txt log file to check out, that's be great.
I need to know the column 'names' that AEM uses for the following:
TIME
RPM
TPS
TIMING
AFR
BOOST
That way VDR can look 'inside' the file and extract only the data VDR needs to work its magic without any need of copying/pasting by yourself.
Oh yeah, no more RPM trim requirements,plus it calculates HP/TQ from every row of data now,not just every 50 rpm As long as you logged your TPS, you dont need to be as finicky about exporting JUST the WOT section too, it has a TPS trim option that will only read the lines that were at WOT
Old Jun 20, 2010 | 11:20 AM
itzwolf's Avatar
TIME
RPM
TPS
TIMING
AFR
BOOST
Jack,
This is the first few lines of an exported log from an AEM Series 2, the only difference is "Ign Map" in Series 2 vs being called "Ign Timing" in Series 1, and "Ign Timing" in Series 2 is "Ign Timing #1" in Series 1 being after any trims (from knock etc.) it is the ACTUAL timing if my memory serves. I could double check if that is reversed but I am pretty sure thats the way it is...
Code:
       Time/s	     Air Temp	  Engine Load	 Engine Speed	      Ign Map	   Ign Timing	Injector Duty	        O2 #1	     Throttle
       10.840	    136.40000	     -1.75081	   3671.09375	     26.94531	     26.94531	      5.19562	     14.41125	     18.81409
       10.860	    136.40000	     -1.70389	   3671.09375	     26.94531	     26.94531	      5.20707	     14.46844	     18.94684
       10.880	    136.40000	     -1.67413	   3671.09375	     26.59375	     26.59375	      5.23758	     14.46844	     18.81409
       10.900	    136.40000	     -1.69015	   3675.00000	     26.59375	     26.59375	      5.23758	     14.46844	     18.94684
       10.920	    136.40000	     -1.62721	   3683.59375	     26.59375	     26.59375	      5.25666	     14.52563	     18.94684
       10.940	    136.40000	     -1.64323	   3678.90625	     26.94531	     26.94531	      5.23758	     14.58281	     19.07806
       10.960	    136.40000	     -1.62721	   3678.90625	     26.59375	     26.59375	      5.26047	     14.58281	     19.07806
       10.980	    136.40000	     -1.71991	   3691.40625	     26.59375	     26.59375	      5.27192	     14.52563	     19.34052
       11.000	    136.40000	     -1.56426	   3695.31250	     26.59375	     26.59375	      5.34821	     14.58281	     19.34052
       11.020	    136.40000	     -1.59631	   3699.21875	     26.59375	     26.59375	      5.33677	     14.58281	     19.47327
       11.040	    136.40000	     -1.51734	   3699.21875	     26.59375	     26.59375	      5.37873	     14.58281	     19.47327
       11.060	    136.40000	     -1.44066	   3703.12500	     26.59375	     26.59375	      5.42450	     14.41125	     19.73572
       11.080	    136.40000	     -1.47041	   3707.03125	     26.59375	     26.59375	      5.45121	     14.41125	     19.73572
If you need full logs for anything let me know, I'll be on later today.
Old Jun 20, 2010 | 11:40 AM
Originally Posted by itzwolf
Jack,
Ok cool, I will see if we can't set it up to look for one of the timing labels and if it doesn't find it, it will look for the other options AEM used. So when you export a text file of your log, you can get it to automatically save it as a .csv file?
Old Jun 20, 2010 | 01:17 PM
itzwolf's Avatar
It saves as a .txt file but I drag the text file to Excel and can save it if needed. If you can get it to parse the text file though that would rock saving that step completely. What I pasted is exactly how the text file looks when opened.
Old Jun 20, 2010 | 05:20 PM
Should be able to get it to work as a .txt file.
Old Jun 20, 2010 | 06:08 PM
BillSpec's Avatar
Converting a couple logs today.
Old Jun 27, 2010 | 11:13 AM
BillSpec's Avatar
Do I need to DL a new VDR? I currently have 5.71 and it doesnt even show a graph with the default data....
Old Jun 27, 2010 | 01:00 PM
Yes, v6.00 will be a full stand-alone version and will accept exported AEM EMS log files. Unfortunately, v6.00 is ready yet so you'll have to wait a bit longer :/
Old Aug 28, 2010 | 09:36 PM
bbarnhill's Avatar
BTW ... 1.0.6 of Virtual Dyno will release tomorrow and it already supports AEM logs. Just so you know.
Old Aug 29, 2010 | 03:24 PM
BillSpec's Avatar
Lol thanks... ya i got them to work already.
Both are great!
Old May 17, 2011 | 08:39 PM
tracknut's Avatar
So i tried this method and got some slightly skewed numbers with a CF of .95 i'm reading about 20% higher than expected . Does anyone know there has to be a certain configuration on the AEM for loggin priority ?
Old May 25, 2011 | 04:01 PM
BillSpec's Avatar
Default values work. Export as text on current zoomed area from 100% tps to 100% . Other than that, idk. Look for a spike in the graph, or shorten up the rpm slider and see if it changes...
killerpenguin21
Apr 28, 2018 08:26 PM
bluedemon199
Mar 31, 2017 02:10 PM
danike
Apr 22, 2014 03:52 AM
racer135
Jan 5, 2010 08:23 PM
