AEM EMS Get tuning help for your AEM EMS system.
ID1000 Settings
Old Feb 15, 2011 | 09:22 PM
k20turbo's Avatar
ID1000 Settings
I am putting some Injector Dynamic 1000's in my car in a few days does anyone have the settings?
Old Feb 16, 2011 | 08:54 AM
kreionic's Avatar
just start with the latency values that are in the box and adjust them accordingly
Old Feb 17, 2011 | 06:35 AM
k20turbo's Avatar
I did not get them with mine, I bought them used .... Anyone??
Old Feb 17, 2011 | 07:41 AM
browningderek's Avatar
email ID. they will be glad to help you.
Old Feb 17, 2011 | 02:39 PM
griceiv's Avatar
series 1 or 2?
s1 ecu's don't correctly read voltage meaning you have to adjust the latency tables provided by ID.
Old Feb 17, 2011 | 08:34 PM
k20turbo's Avatar
Originally Posted by griceiv
series 1 or 2?
Series 1
Old Feb 18, 2011 | 07:21 AM
series 1 or 2?
how would one do that?
Old Feb 18, 2011 | 07:27 AM
k20turbo's Avatar
I would like to know as well, all I did last time was run the wizzard and that was it... There is no option for the id's in the wizzard
Old Feb 18, 2011 | 12:44 PM
i just converted "ms" to "usec"...... FIC told me how. 1ms=1000usec
Old Feb 18, 2011 | 01:53 PM
griceiv's Avatar
with the car running, measure the battery voltage with a multimeter, then compare it to what the ecu says it's using to calculate the battery compensation. shift the voltage axis from the sheet ID gives you to match with what your ems says.
Old Feb 20, 2011 | 06:52 PM
aahhh. that would explain why my ems only reads 13.8v. and if this is off then the fuel tables will be off when i change it?
Old Feb 21, 2011 | 06:40 AM
griceiv's Avatar
yep, changing the battery compensation will require a change to the fuel map.
Old Feb 22, 2011 | 07:29 AM
so where in the aem do i sync the battery voltage?
Old Feb 22, 2011 | 07:51 AM
griceiv's Avatar
I'm not sure you can change how the ecu measures voltage.
Old Oct 20, 2011 | 04:25 AM
BadAssEvo's Avatar
Do you have to remove the resistor box when you install this?
