AEM EMS Get tuning help for your AEM EMS system.
Swap between AEM Infinity and Stock ECU
Old Nov 5, 2020 | 02:47 PM
Construct's Avatar
Originally Posted by Lumpy Sticks
Lingenfelter makes something like that for the LS engines. Lets you install a later model 58x engine into a vehicle that uses a 24x ecu. Dont see why it wouldnt be possible for someone to make one like that for the Evo.
I'm fairly certain the Evo sensor is hall effect, which makes the circuit relatively easy. It might take an extra revolution of the engine to sync up and find the index tooth, but that's not a big deal as long as the stock ECU doesn't freak out about getting a cam position sensor signal but not a crank signal for a brief moment.
Old Nov 6, 2020 | 09:38 AM
Abacus's Avatar
Originally Posted by 2006EvoIXer
Cool. Do you have a link to see how it's installed?
There isn't a full install guide online that I'm aware of but its going to be similar to the other ECU's. Wideband and a few other items can be added also.
JRR offers packages for the 8/9 and other platforms.
https://johnreedracing.com/collectio...9-m130-pnp-kit
Old Nov 6, 2020 | 01:23 PM
2006EvoIXer's Avatar
I couldn't find mounting kit for the 12 tooth trigger. Would be nice to have both the oem trigger and the 12 tooth trigger in place so we don't need to screw around with swapping.
bryonboals
Jun 7, 2014 05:28 AM
Paul Walkin
Jun 30, 2011 09:27 PM
BPU
Jun 1, 2011 08:39 AM
skatermsmn
Jul 24, 2009 04:42 PM
lacartus
AEM EMS
Dec 19, 2004 09:11 AM
