AEM EMS Get tuning help for your AEM EMS system.
AEM EMS and the Dealership
Old May 14, 2004 | 08:53 AM
Hooptie157's Avatar
Hello,
I'm going to get the EMS within the month and I had a question regarding the dealership and the EMS. If I took my car to the dealership to get an Oil Change and for some reason they wanted to clear the service codes on my car and hooked up their diagnostic tool, what would happen? Would their's clear everything in the EMS or would it just come up with an Error? What if they tried to put a code through, would anything happen then?
I mean I know I could just put the stock ECU back it but w/ 272's I don't think she'll idle good enough to make it there.
Old May 14, 2004 | 09:56 AM
metaphysical's Avatar
Registered User
No check engine lights (you can program them as warning lights, shift lights, etc.) , so scan tools won't work. This can be both a good and a bad thing. But, as far as oil changes, no worries.
Old May 14, 2004 | 10:16 AM
Hooptie157's Avatar
Well if scan tools won't work and I develop a problem, let say a miss fire for example, how would I know that?
Old May 14, 2004 | 10:27 AM
4G63>OOOO's Avatar
I would ask how you're planning to get inspected?
Old May 14, 2004 | 10:32 AM
chinalfr's Avatar
I did try to plug a datalogger to the OBD2 port. No response from the EMS. So maybe pulling code from the port will get the same result?
Old May 14, 2004 | 10:39 AM
Hooptie157's Avatar
Thats a good question too. With the AEM EMS and 272's is it possible to pass NJ emissions with a cat?
Old May 15, 2004 | 10:26 AM
Registered User
The only thing that won't work is a OBD-2 emmissions test. Otherwise your fine. The datalogger and a good mechanic will tell you a lot more than an OBD code.
Old May 18, 2004 | 08:49 AM
Hooptie157's Avatar
Do NJ emmissions tests do the OBD-II diagnosic and if so how am I gonna pass it with EMS and 272's?
Old May 18, 2004 | 06:54 PM
Pitbul09's Avatar
To avoid problems why dont u just remove it when you have to have service to inspection , when does the car have to be re-inspected 4 years?
Old May 18, 2004 | 07:21 PM
Registered User
PA Inspection is every year, along with our new Emmissions test.
We have a gas cap pressure test and a visual engine compartment check.
So running an EMS gives you no problems.
As for NJ, I have no idea.
Some states have secondary options for vehicles unable to take an emmissions test through an OBD2 port.
Old May 19, 2004 | 10:30 AM
Hooptie157's Avatar
Pitbull: Yeah it get inpected in another 4 years. I was planning on just putting the stocker back in but I'm not sure if it could hold the idle with 272's. I can't go sputting into inspection.
Old May 21, 2004 | 08:25 AM
steinvb12's Avatar
I was wondering the same thing myself. I also am thinking about getting an AEM EMS, but worry about the inspection and warranty aspect of it. I know it is just a plug and play ECU, but the 3.5 map bar sensor will also be installed.
If I were to take the AEM EMS out, and put the stock ECU back in, will I have to remove the 3.5 bar sensor as well? Or won't it matter?
Just wondering if the stock ECU will try to read from that sensor instead of the stock one??
Anyone have any ideas?
Old May 21, 2004 | 08:54 AM
chinalfr's Avatar
You have the choice of either running EMS with MAF (Mass Air Flow) or speed density.
If you run EMS with speed density conversion, you will need to reinstalled the MAF sensor back. The stock ECU will only take MAF reading. As for the MAP & AIT sensor, you can leave the sensor on the car without connection. Some wiring rearrangement will be needed.
If you running EMS and using MAF, you just need to swap the stock ECU back.
Old May 21, 2004 | 09:34 AM
Pitbul09's Avatar
Hooptie157 you can always get ur ecu flashed.
Old May 21, 2004 | 09:45 AM
YellowFever's Avatar
Scott, Brian does have an ECU Flash, but the Dynoflash
