2 n00b questions.
The door remotes are no problem as those are handled by the ETACS computer which is separate. The only things you will lose will be the auto IC sprayer function and the engine disabler security function.
The EMS holds one map, the map you are using. If you want to switch maps you need to connect a laptop and upload a different map. You can however have one map that uses a switch to control high or low boost, high or low timing, and high or low fuel or nitrous or whatever you want.
Thx for the info, it's exactly what I wanted to know.
Other way around. You can use the switch to manually turn the sprayer on and off, but the Auto feature is controlled by the stock ECU, which is not in the car...
My spryer is controled automatically by the EMS.... pretty simple to set up. I have it set to turn on at 10 psi of boost.
Keith
