Passing smog question..
Before I start, I tried searching and couldn't find anything.. so it's either really obvious or I just don't know..
So as you all know, I recently bought my car.. I went to smog it today and I didn't pass, as I have the AEM standalone and it didn't connect to the OBDII to do the test.. what do you all do to pass around here? I have a 35r turbo attached so putting the exhaust back on may not help any.. I need to get it done within the next few weeks.. :( Thanks! *edit* Looks like the problem I'm running into is that even if I find someone to "tip to fix" the fact is that i'm using AEM and they can't connect to the ECU... how do all of you with AEM do it? :) |
From what I know any standalone will make the car fail. Reconnect your factory ecu?
I too would like to know how people street drive their cars with a standalone. |
im pretty sure that a car with an evos wont pass inspection from what iv been told. only the factory ecu has the info to send to the inspection computer to allowe it to pass and as far as the smog your on your own massachusetts just got rid of smog testing :D
Originally Posted by silver9mr
(Post 6748490)
bump.. problem not solved actually.. :(
updated the question.. :)
swaped back stock injectors, maf and stock ecu. drive around till the ready codes clear. take to DEQ or emissions. some of that may require rewiring.
Originally Posted by SR20S13
(Post 6754037)
hey same here i will need ot get a sticker in my car but i have aem ems hwo will i go thru this? since u say it wont match up at all
i do not have the stock ecu handy at all so im stuck with aem ems
Originally Posted by DJJimGreen
(Post 6754147)
I was thinking of doing that but.. do you think the codes will clear with a 35r turbo in there and no cat? The 02 code would be thrown at least right?
Originally Posted by amui07
(Post 6755754)
There's a Perrin o2 sim or even simpler, using antifoulers to get the rear o2 not to throw the CEL. Search the forums and you'll find plenty of info.
there a many other ways like a friend who also has an evo
if you know wut i mean |
(Post 6754147)
There are several ways of having a street driven evo on an AEM. However most ways "bend" the rules and therefore are not discussed much on the forums.
Your best bet is swapping back to stock ECU. If you know someone with a cable, you could do a quick a dirty tune so that the car would run a little better on the 35r. If you go over to the stock ecu tuning forum, they have several methods of getting around different CEL's that may pop up. As far as the other methods, czilla may be on to something. Also in my state, some counties don't require emissions while others do. If I happen to live in one of the counties that didn't require emission, I would be good. There are several ways of "living" in those counties. That's as much as I'll say on the subject. Good luck. |
