Question for anybody who has aem ems!!!!
Hey guys I recently purchased an Evo IX SE. It has a fully built motor, gsc s2 cams , 1000 cc injectors ,fully built by cbrd with a cbrd bbk full turbo setup. Straight pipe ect. The car runs flawlessly and pulls like all hell. But obviously it burns gas like a mofo. Right now it's on a stock ecu flashed and tuned by Chad blocks shop. My question is. If I get an aem ems.. I would then have an option for a multi map setup? Max power on pump gas (93), a low boost Eco mode type of map, and a race gas map.. Is this difficult to do? I'd really like to get a map to just drive to work and not burn all this fuel. I'd appreciate any good input. I'll be checking this thread multiple times a day to see if anyone can give me some clarity on this. Is there any other way to make this happen as well?
Yes the aem infinity supports this.
You can have maps fuel and ignition and boost profiles via a trim pot. You also have full 3D boost maps using ethanol % and trim pot position. Using that you can adjust your lambda targets and you ignition maps. So if you want to run a low grade gas map and a high grade gas map you can and you can switch between the two via 0-5v input. Hope that was the answer you were looking for. |
I will screenshot some of the tables tonight when I am at my computer.
Sweet brotha! Look forward to seeing it! Feel free to chime in guys!
Bump. Still seeking more info!
Bump!
3 Attachment(s)
I am not sure why you keep bumping, I sent you a very direct answer to your question. Yes you can do all the stuff you are asking about. You will need a trim pot.
Thx boz
http://www.aemelectronics.com/?q=pro...ition-trim-pot
Like 40$, running one on my AEM V2 with Kill, 25 lbs and wastegate pressure (14) theboz was right though |
So, I just picked up a IX and it has aem v2. I’m just so clueless of what it is and why you would want the aem v2? |
