Matt Dennison aka o-townFLA Track REBUILD
Old May 17, 2013 | 09:25 AM
o-townFLA's Avatar
Talking Matt Dennison aka o-townFLA 2.3 GTX3076 REBUILD
Blog---> http://timeattackusa.blogspot.com/
2.3 MOTOR BUILD
A little insight of what's been going on with "Matt Dennison" aka "o-townFLA" or simply known as "Matt"...
All intentions were to go to a track day and instruct. Seeing everyone blast around the track or me sitting in the passenger seat wasn't necessarily*boring but the competitiveness in me wanted to be in the driver seat. So without fully going over the car I hit the "time attack" session... Bad idea...*
After the (2) TA session my car had a little more valve train noise than usual. Trying to figure out the noise at the track with a marauder of people you can only imagine all the inputs and ideas of what might be wrong. So while at the track we all finalized that we couldn't really determine what was wrong. Other than the new noise and that I was super low oil...
So I dropped the car off at Road Race Engineering to have their assistance. Within a few hours we have found the problem. A motor killing spun bearing...
So the next question was what to build, how strong will the build need to be and what all needs to replaced...
So the final build would be the following with a few new extras:
Jacks Transmission 2.3 Stroker*
- Wiseco pistons
- Manley H-beams
- AMS oil pan w/ scrapper
Jacks Transmission rebuilt head
- Kiggly HLA pressure regulator
- Cosworth M3 cams 280/272
Jacks Transmission rebuilt tranny
Front Mount Earl's oil cooler
I've always been weary of running E85 due to its inconsistencies. So I've always ran 100 octane making a decent 450/400 at 26psi. With this build I decided to bump up to E85 but would do it right...
- ZEITRONIX Ethanol Content Analyzer
- Walbro 400lph*
- FIC 2150cc injectors *
- Fuel Lab Fuel Pressure Regulator*
My current turbo setup is the cast HAFE manifold with a newly released GTX3076R bolted on.*
Well the blessed people at Road Race Engineering to include Mike, Rossy, Honda, Sam, Lod, Chris, Robert, Matt, Art, Ruben, Lydia, Gus, Rick and Scott have been a tremendous help and I will forever be in debt to them...!!!
Thank you to those that have helped pave the way to the podium for me
- Robi @ RobiSpec
- Yukio @ Turbo By Garrett
- Scott @ ACT
- Chris @ KW Suspension
- Jack and Chris @ Jacks Transmission
- Ziggy @
- the boys @ MAP
- Abby @ mil.spec
- GoPro
- SPY optics
- God @ awesome...!
MOD list:
- ROAD RACE ENGINEERING dyno tune
- ROAD RACE ENGINEERING turbo kit
- ROAD RACE ENGINEERING motor mounts
- TURBO by GARRETT GTX3076R
- SPOOLINUP C.O.P.
- ACT Xtreme clutch
- ACT Prolite flywheel
- MIL.SPEC 65mm Throttle Body
- MIL.SPEC R2 version Intake Manifold
- BERK TECHNOLOGY high flow catalytic converter
- JACKS TRANSMISSION 2.3 stroker motor
- JACKS TRANSMISSION tranny
- AMS oil pan
- Earl's front mount oil cooler
- Mishimoto radiator
- Mishimoto air diversion plate
- Mishimoto silicone radiator hoses
- Mishimoto slim fan
- Prosport oil filter adaptor plate
- AMSOIL fluids
- Cosworth 280in/272ex M3 camshafts
- ETS 3inch front mount intercooler
- Dejon dual stage MBC's
- Dual map switch for 91/E85
- Megan 3inch TBE
- Fuel Lab fuel pressure regulator
- Walbro 400lph fuel pump
- Fuel Injector Clinic 2150cc injectors
- 42 draftdesigns water temp housing
Suspension Modifications:
- ROBISPEC aligned and corner balanced
- ROBISPEC KW suspension RACE 2-way adj. coilovers
- ROBISPEC 26mm 4-way adj. swaybar
- ROBISPEC swaybar endlinks
- ROBISPEC spherical bearing control arm kit
- Perrin PSRS - offset
- K-Mac camber/caster plates (front)
- Cusco pillowball top mounts (rear)
Wheels/Tires Modifications:
- Konig Runaways 18x9 +30
- Volk RAYS Gram Light 57 maximum 17x9 +22
Interior/Exterior Modifications:
~~interior~~
- ZEITRONIX wideband Air/Fuel ratio gauge
- ZEITRONIX e85 Ethanol Content Analyzer
- Sparco Evo seats
- G-Force 6pt harnesses
- Prosport 60mm Premium boost gauge
- Prosport 60mm Premium oil temp gauge
- Prosport 60mm Premium water temp gauge
- Prosport 60mm Premium oil pressure gauge
- WorksBell Rapfix II quick release
- WorksBell short hub
- MOMO mod-8 350mm steering wheel
- Autopower 4pt roll bar
- Gruppe-S 60mm gauge panel
- GOPRO cameras
~~exterior~~
- Voltex GT wing - type 5
- Voltex rep. race bumper
- APR rear diffuser
- OEM vortex generator
- baller yellow tow hook
Old May 17, 2013 | 10:55 AM
bstgsr's Avatar
Nice! good luck with the build
Old May 17, 2013 | 01:10 PM
gr8dc2b's Avatar
"Let's put the women and children to bed and go lookin' for dinner!" "Let's open up a can of kick a$$ ... [and] let the paramedics sort 'em out." Take it to 'em Matt!!!
Old May 18, 2013 | 06:01 AM
apagan01's Avatar
Nice work... gl on the next round.
Old May 18, 2013 | 07:44 PM
o-townFLA's Avatar
Thanks Andy. 87k on the stock motor with heavy track mileage... It was due for a rebuild...
Old May 21, 2013 | 12:30 AM
importmachine's Avatar
I've seen your car a couple of times at RRE. Everytime I visit Road Race it just happens to be there and always wondered what was up with it. Who's tuning the car? Rick? GL with the rest of the build. I'll be following your progression.
Old May 21, 2013 | 04:20 PM
o-townFLA's Avatar
I snapped a balance belt bending all my intake valves, the I was plagued with leaky valve seals most recently before I spun a rod bearing.
Scott Gray tuned my car and it has never had a hiccup
Old May 21, 2013 | 04:35 PM
apagan01's Avatar
Not bad at all !
Old May 23, 2013 | 09:44 AM
o-townFLA's Avatar
This is my old tune, 91/100 octane overlay... Boost was 23/28psi...
Boost plot...
Old Jun 1, 2013 | 01:34 PM
o-townFLA's Avatar
Got the motor dropped in yesterday. Still need to install the t-case for it to be completely installed... Had to wait on some gaskets or it would have been dropped in last week. But the worst thing was that when i opened the tranny box up Jacks Transmission had sent all of the needed gaskets in with the tranny. Oh well...
While the motor was out I removed all the EGR stuff...
Next up is to mount/install the Fuelap FPR, Zeitronix Ethonal Content Anyalyzer wired in, Walbro 400 install w/ it hotwired in, and install/mod some more aero...
Hope to get it cranked so I can get some break-in miles on the motor, swap out the old injectors for the FIC 2150cc's and get her dyno'd on 91 and E85...!
Track day plans are to hit up some HPDE for some shake down runs and then run Super Lap Battle/GTA in November to finish out the short track year...
Sweet Jacks Transmission packaging...!!!
We're off to the races....
Old Jun 8, 2013 | 02:58 PM
o-townFLA's Avatar
SHE'S ALIVE...!
Amazing...! She fired up on the second crank...!
With the help of Lod's expertise and constructive criticism (who is also Formula Drift driver Joon Meang's crew chief), she fired right up. Help from not only Lod, but from all the pros at RRE have made this all a breeze...
After a quick 20 mile jaunt around Sante Fe Springs, CA I came back to the shop and drained the oil and cut open the filter for inspection of any type of oil conatamenation.... Results looked good...
So it's now officially time to get in some varying RPM break in miles...
Old Jun 8, 2013 | 03:15 PM
o-townFLA's Avatar
Here's some craftiness....
I decided to make a front mount oil cooler setup but still utilize the OEM pusher fan. In doing so I needed to make/fab a new power steering cooler...
I removed the front loop cooler to make room for the larger oil cooler and replaced the power steering cooler with a smaller core more efficient. I also relocated it to the front right wheel well...
In the above pic, the oil cooler is just in a moc setup but will be fabbed to sit there...
At the moment, the oil cooler lines are looped. As I'm holding of on installing the oil cooler until the motor is broken in completely.*
Old Jun 8, 2013 | 03:22 PM
o-townFLA's Avatar
The car is close but still far from total completion. Well to think of it it'll never be completed...
Still to do list
- route/fab/install oil cooler
- install Walbro 400
- install FIC 2150cc injectors
- install ZEITRONIX ECA readout
- install voltex rep bumper w/ modified brake ducting inlets
- install Binary brake ducts
- dyno tunes
- prep for track day
- track day, track day, track day
Old Jun 11, 2013 | 11:14 AM
Jacks Transmissions's Avatar
Gold Sponsor
Wow, what a great thread! Nice to see everything working out so well and clean! We really appreciate you guys putting your trust in us and hope the setup kicks some serious butt out there
Old Jun 12, 2013 | 08:37 AM
o-townFLA's Avatar
Thanks Jack and Tim. You put out phenomenal stuff at Jacks Transmission!
