Fuel Pump & White Gauges
Old Apr 26, 2003 | 11:14 PM
Elias's Avatar
I am after a fuel pump for my Lancer GSR, as i am transplanting a 4G63. Any ideas on what i can use, it won't have to support more than 18 psi and appr. 240 kw at the flywheel.
I am also after the white display for my dash - speedo, tacho, fuel, etc.
Anybody??
Old Apr 27, 2003 | 12:48 AM
evo_x_coupe's Avatar
Elias. You can pretty much replace the in tank GSR fuel pump with an EVO one. They are pretty hard to find though. If not, you can use something like a Bosch Hi-flow external in line pump and a surge tank in the boot if you want. A little more stuffing around but at least it wont ever lean out and kill your engine. The GSR has a problem with when it runs low on fuel it can lean out around cornering and its good you thought of it especially now you are gonna run the 2 litre turbo. The EVO fuel tank has built in baffles which help in protecting leaning out, but a surge tank is always the 'safer' option.
I have a 070 Bosch Hi-flow EFI unit brand new and still in its box I am selling for $120 ono. Its not a ballistic pump as pumps go as it flows 130 litres/hr (400-450HP), but it will be more than fine for the power figures you have described. Actually a lot of guys use these ones for their VL turbo commodores. I can COD it to you in a postpak as i only live in Newcastle and it will be cheap freight to Sydney - should be less than $10.
White faced dials you can pretty much pick up anywhere but they do cost a fair bit. I cant justify why they sell for over $200 for some small bits of plastic? hehehe... they do look good though, and I am after a set myself on the cheap.
Old Apr 27, 2003 | 10:04 AM
Elias's Avatar
Sent ya a pm
