Cusco LSD RS 1.5 Way For Evo VII Only
Old Nov 21, 2006 | 06:36 PM
Gruppe-S's Avatar
Hey guys,
We got a cancellation on a special order for JDM EVO VII CUSCO LSD RS 1.5 WAY. Customer already put down a deposit, so we're letting these things go for cheap!!
The Cusco limited slip differential is designed to provide maximum traction that is most often lost in hard off-the-line acceleration, these L.S.D. kits are designed to integrate with your factory transmission. The unit will sense when one wheel starts losing traction due to track/road conditions, hard cornering, and/or torque steer. Once it detects the slippage, it will compensate by shuffling the power from side to side to overcome the loss of traction. This translates into better track or quarter mile times, and more efficient use of the engines power.
With the Type RS, the initial torque is absorbed by the RS springs therefore the initial torque comes on gently compared to the Type MZ which comes on stronger as it uses cone plates and response of the LSD is better, as the friction is lower.
* 1.5 way LSD
Activates under acceleration while the understeer is less than on the 2 way LSD.Recommended for drivers having difficulty with 2 way LSD understeer and one way LSD braking.
CUSCO LSD (FRONT) RS 1.5 WAY
-ACD car ONLY
-EVO VII ONLY
$1159 shipped to Australia (normally $1500)
CUSCO LSD (REAR) RS 1.5 WAY
-AYC car ONLY
-EVO VII ONLY
$959 shipped to Australia (normally $1199)
Only 1 of each at this price. THESE ARE GOING FOR >BELOW< COST! Please contact us with any additional questions. If these prices dont seem crazy already, keep in mind a $160 USD (LSD's are heavy!) shipping fee has already been calculated into the price. Thanks!!
Gary
gary@gruppe-s.com
510-783-5300
510-783-4300 fax
