CC Coupe foglights
CC Coupe foglights
I've been curious about these for a while, since not very many coupes seem to have them (well I've only ever seen one) and the holes in the bumper look sort of weird being empty. Does anyone know where I can get them? or a similar light which will fit the hole?
Any info appreciated!
Okay, this sounds pretty weird, but i like flush mounted driving lights... soo...
You know the downlights you can buy at your local hardware store ? well...
I removed my Front bar, drilled holes, and fitted them.. as the globes are 12v 50watt.. although you have to run your own cable and a relay, it runs fine
And you can get them at different angles.. and styles..
Pete
ps.. i'll post photos later on
Pete
Can we get them for ours like the CE can get them from Mitsu ?
They are pre made ones, that you just take the plate thing out, and clip in the new ones..
But being mitsu, they are dear as anything..
Its very hard to come across some where i am, thats why i made my own, and work as effective if not better.. i tend to find that if i am driving in the middle of the road, i can read letterbox numbers in a normal street.. they are very wide.. but i only use them on the open road, not in town, if i did i'd have to change the angle of the globes that are in them
easy.. its ran by a relay for the 12v, and for the switch i used the park lights, and then in between the parklight switch and relay i fitted another switch to turn them on/off so they can be toggled form the cabin itself..
all i needed to do to install was drill the holes perfect size as the outer bit of the light and pop them in.. i did it the hardway and took my front bar off, also to conceal the wiring a lot better
