considering turbo questions....
I have just a few questions about it.
I currently have a Apex Turbo back Exhaust, and intake, and a MBC.
now I am currently looking at the (I could be wrong) the GT3071R, the same one you used on the time attack at Talledega.
anyways my questions are:
1. If I bolt up this turbo to my stock motor, am I going to have problems with reliability adding that much power?
I mean, is it neccessary to for that kit to add go the route of new timing belts, head gaskets, all that stuff?
I wil be putting in head studs, a new clutch and probably either an AFC or a utec.
also a wideband too.
Is there anything else I am going to need to be running conservative 19psi, with pump 91 gas?
like I said those other things will probably be done in the future, just not right now If I get the GT3071R kit now.
any info? or ideas thanks
motor work is not necessary and other then waht you listed the only thing I can think of that you would need is injectors. thats a great kit for the track. It had alot of power, enough to have Jon smack me around in the turns.
Eric
Eric
