Congrats to Dan, 9's!!!
Man almost had him....but Dan's car still runs lol...That was awesome. Seems to be a really strong stroker set up. I know the DSMs have frequent reliability issues with strokers....or at least I have seen more that have probs than the built 2.0. I am anxious to see the 2.0 in this car. I will have a similar set up soon....but I just want tens on street tires lol. Shouldn't too hard with that gt37. Conrats Dan!
Originally Posted by fimotorsports
thanks everyone. I'm going to have Martin setup my AEM for no lift shifting, and see if that helps out. I was hitting the rev limiter at 8700 on each run, I moved it up to 8900 so I can make it through the 1/4. Those runs were not on slicks, they are radial tires. Tire spin has been an issue, still playing with the 2 step and tire pressures. I will be purchasing some Hoosiers to get some more traction out of the hole.
Here's another in cabin on the finals.
9.91 at 144 mph
9.91 at 144 mph
thanks, boost spikes to 38 psi and holds at 35 psi. I think I may need a stiffer bov or wastegate spring to hold to 38. Last time I weighed in at 3250 but added some weight here and there so probably around 3350 at this time.
Dan 9 and 10 sec. passes - it`s nice.
BUT more interesting to know which problems do you have after all these launches
I had issue with ignition,shifting at high RPM,misfire and more....
Interesting to hear what is yours?
