Coming to Florida, Flashing this weekend!
We are going to be in the area this weekend and would be willing to do some custom tuning while we are out there. I need 4 guys to make this trip happen. Give us a call at the shop and reserve your spot.
Sorry about the short notice! Here is some additional info about what we have to offer:
Benefits of the AMS Flash :
Base flash for your current list of modifications. This is also followed up with a quick road test with logging to ensure that everything is working properly. You can expect at least a 20whp and 20ftlbs torque gain. We will be doing these all day, in-between the custom flashes on a first come, first serve basis. $180
All base flash cars must have:
Custom flashes will be scheduled ahead of time, and we will be doing 6 per day. These will be full tuning of your vehicle’s A/F curve and timing curve. Also, for the EVO 9 the MIVEC timing will be optimized. As you know every car is different, some are very different, and this will bring out the very best in each car. Unlike the base tunes, they will be adjusted for your specific car to extract the most horsepower and torque possible. Actual numbers will depend on the modifications to your car. Each custom tune will have its own 2 hour time slot. $395
In order to reserve a spot I will need you to send us a $100 deposit over the phone.
To pay the balance for your flash you can either, pay in full over the phone before hand, or you can bring CASH to the flash appointment. For those of you who will be receiving base flashes the same will apply, you can pay over the phone in full, or you can bring cash and pay at the completion of your appointment.
- RPM limit increased (customer specified)
- Set 2-Step launch RPM (customer specified)
- Boost control (Custom and Base flash)
- Raise fuel cut to safe level, or remove completely
- Improved idle with cams
- Air/Fuel curve optimization
- Timing CURVE optimization
- MIVEC Tuning on Evo 9’s (Custom and Base flash)
- Fuel Pump (Recommended)
- Stock injectors
- Stock MAF intake pipe
- Stock Turbo
- Stock Fuel Pressure
