Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AMS.... Lifter?
Old Nov 26, 2006 | 09:06 PM
Ackerson's Avatar
The 3g, 99, or revised lifters(whichever you choose to call them) are the same part number as the Evo lifters.
Old Nov 26, 2006 | 10:13 PM
Soon2BEVO's Avatar
If that holds true, well that makes the JAM ones a deal. My EVO lifters tick like crazy and many other people with EVOs have complaind about it. Ive heard of 5 or more people buying the JAMs and the ticking is completely gone.
Old Nov 26, 2006 | 10:48 PM
Spec'd's Avatar
I have heard the same thing about Jam lifters alleviating the tapping noise.
Old Nov 27, 2006 | 12:20 AM
evo3matt's Avatar
my jams still tick, or my revolvers, something ticks lol
Old Nov 27, 2006 | 05:46 AM
Ackerson's Avatar
The JAM lifters are repackaged Topline or Melling lifters. They are just replacement EVO lifters and if you look around you can get them for under $130 for a set. The lifters are going to tick a little bit, that's normal. You will definitely know when you get a stuck or abnormally ticking lifter. It's very loud and is usually caused by not changing the oil on a regular basis.
Old Nov 27, 2006 | 10:40 AM
Spec'd's Avatar
Good information ... Thanks !
I've heard of Melling before...
I once used a Melling oil pump for a small block Chevy... back in the day.
Old Nov 27, 2006 | 10:44 AM
Spec'd's Avatar
Based on Revolvers Specifications... That's understandable.
What valvesprings are you using ?
Old Nov 27, 2006 | 03:32 PM
mitsuorder's Avatar
So does anyone have a direct source for the Topline or Melling lifters?
Old Nov 27, 2006 | 08:20 PM
unknown2's Avatar
I talked to JAM today and they said the reason for the lifters ticking is because most of use don't use the right valve springs and retainers. So now i'm going to get some valve train components and try that first before i buy new lifters. Hope its not too late.
Old Nov 27, 2006 | 08:30 PM
hondafan's Avatar
some people are still on stock springs/retainers, are these "not the right ones"?
Old Nov 28, 2006 | 06:52 PM
Ackerson's Avatar
If you have aftermarket cams, the stock retainers contact the valve stem seals. Valvesprings and retainers should be a mandatory item when upgrading cams.
Old Nov 28, 2006 | 07:00 PM
Spec'd's Avatar
+1
Old Nov 28, 2006 | 08:51 PM
hondafan's Avatar
yeah, i'm saying people with stock cams and noisy lifters. do these cure the problem? or are they not the right springs/retainers?
Old Nov 28, 2006 | 08:56 PM
Rich@Orbital's Avatar
this may be a stupid question, but does anyone know if conversion to solid lifters would alleviate this problem (obviously assuming one was to use solid-type cams such as JUN)?
Old Nov 28, 2006 | 09:02 PM
hondafan's Avatar
there is a company that makes them(forgot who), but i don't know how daily driver freindly they'd be.
