Gary C's 600 WHP Time Attack EVO
https://www.evolutionm.net/forums/sh...d.php?t=260486
Tires are Nitto 01's 275/35/18.
Ohlins coilovers for the time being.
APR front lip with a pricey custom splitter(call AMS for pricing).
Thanks Guys for the compliments
I believe the offset is 27 and 40, the brakes made the wheel fitment a nightmare. The 275/35 choice is the same size as the Hoosier slicks I will be running when we dial the suspension in. The suspension set up now is more of a DD deal but is trackable.
+27 front & +40 rear?
Any spacers required? I'm planning to run the same setup.
I will try to answer as many of these as possible.
He runs no spacer in the front but a 5mm spacer in the rear.
The suspension are Ohlins DFV. He wanted something more wild but not untill he gets some seat time in the car. DFV's are GREAT coilovers.
The Front Lip is an APR EVO IX CF Lip combined with a custom splitter that we made here. Its a Carbon Kevlar piece with a thick Foam core. It also runs under the entire depth of the motor.
The modifications on the car are as follows:
AMS 2.3 Stroker Engine with Oliver rods and Ross pistons
AMS Ported Race Head
GSC stage II EVO IX Cams
AMS GT35R Turbo Kit (Swain Coated)
AMS FMIC
AMS 3" Exhuast
AMS Motor Mounts
AMS upper and Lower IC pipe (Strapped for Strength)
AMS VSR intake Manifold
Accusump 2QT Oil accumilator
AMS 1000hp Fuel system with Surge Tank
Buschur COP Ignition System
KOYO Radiator with Samco Coolant hoses
AEM EMS with sensors
Exedy Tripple Carbon Clutch
Stasis Alcon 6 piston Front Big Brake Kit
Stasis Alcon 4 piston Rear Big Brake Kit
Enkei NTO3M 18x9.5 +27 offset front +40 offset Rear
Nitto NT01 276/38/18 Tires
Ohlins DFV Coilovers
AMS Rear Trailing Arm bushings
Whiteline Roll Center Adjust
AMS Professionally Corner weighted and ballanced
Street Alignment performed
AMS Front Splitter/ Undertray
APR Front CF Lip for the EVO IX
APR GTC300 Rear Spoiler
Gary, If I have forgotten anything please feel free to jump in here.
There are alot of smaller things that have not been added those are the big ones.
We had dyno sheets up a few weeks ago. I will go dig those up for you guys later on today
AMS FMIC
AMS 3" Exhuast
AMS Motor Mounts
great JOB AMS what kind of front lip is that?!?!?!? i def. want one!!
