Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Tuning Question for AMS
Old Feb 19, 2008 | 09:58 AM
virtuaframax's Avatar
i live in Chicago and i'm pretty close to you guys!
I own a Mitsu 3G GS and i am turboing it. here are the parts that will be installed.
- EVO 8 Stock Turbo
- Forge Adjustable Actuator (9-15psi)
- Megan racing manifold and O2 housing
- Evo 8 stock dp
- Walbro 255
- Begi FPR
- 440cc WRX (non STI) injectors
- Evo 8 LICP and custom UICP with BOV (still TBD)
- Greddy EVO 2 CB (2.5")
- NGK spark plugs 2 range colder than stock
- AEM Uego WB
- AEM Tru Boost
- Autometer EGT
My question is which is the best route for you guys to tune this setup since I will come there to have it pro tune.
Since the car is Sporty and not manual, the evo rom cannot flashed on my ecu and consequently the over 100% load in the map needs to be fixed with a piggyback.
I have an Emanage Blue and the GM MAF with the MAF Translator. Would it be better go with the MAF T Pro?
Let me know your thoughts so that by the time it gets warmer and i have everything installed, i will have the tuning device bought.
Thanks,
Fra
Old Feb 19, 2008 | 08:32 PM
EricJ@AMS's Avatar
Where is the starter located on the auto car? I know on the manual, its up pretty high and I doubt the Evo turbo would clear it.
Is it '01 and up that is ROM tunable? If it is, and I know the load cells are limited, but with a MAF Translator you may be able to get within a good area without a piggyback. I'm not too familiar with MafT Pro however.
Old Feb 20, 2008 | 05:44 AM
the starter issue is solved using a angled spacer that tilt the turbo a little bit up
i know the rom is tunable since i changed the AFR with ECUFlash once i installed header, catback and CAI.
i will go with the MAF translator route and have the emanage installed to solve the over 100% load. the goal is running safely between 9-12 psi (i know it sounds really lame for u evo guys, but until a evo head or forged internals are installed, i dont wanna risk to blow the engine!!!)
Old Feb 20, 2008 | 06:52 AM
Tim@AMSperformance's Avatar
I thought I read somewhere recently that an evo 8 ecu or an evo 8 standalone can be used. The wiring is very very similiar.
Old Feb 20, 2008 | 07:42 AM
Evolude's Avatar
^^Since he has an automatic Eclipse, he is not able to do that.
Old Feb 20, 2008 | 11:19 AM
yup... i cant flash the evo rom on my ecu since no auto evos were made... AEM EMS could work, but i wouldnt pass emission unless i run it with my ecu. and for the amount of boost im going to push (at least at the beginning) is not worth spending 2-3K for the EMS.
im stuck with the MAFT and Emanage and ecuflash at lest for scaling the injectors and everything before 100% load...
Old Feb 20, 2008 | 11:22 AM
Evolude's Avatar
Auto Evos were made, just not sold in the US. I think the majority of the IX Wagon Evos are automatics. Although I don't know if the ROM would play nicely with yours or even if the ECU can be used in your car.
Old Feb 20, 2008 | 11:37 AM
i know the JDM Evo VII GT-A came out auto. some ppl on the club3g.com forums have been working on trying to make it work with our sporty, but with no success... the car stalls after few secs as soon u shift in drive...
Old Feb 22, 2008 | 09:33 PM
anybody else with some inputs? especially AMS
Old Feb 22, 2008 | 11:01 PM
EricJ@AMS's Avatar
Can you easily install anything larger than 440s? I take it the car uses high impedence injectors stock?
Old Feb 23, 2008 | 09:02 AM
youre correct! the injectors are hogh impedance... for my purposes at this stage, a440cc are sufficient and the WRX non sti are a direct drop in!!!
maybe later down the road (with a evo 8 head swap) i will need bigger injectors...
