Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Inside the CNC cylinder head program at AMS: The EVO X Head
Old Nov 14, 2008 | 04:28 PM
AutoMotoSports's Avatar
Tim and the guys in the engine shop have been working pretty diligently on an engine program for the EVO X. With the great success we have had with CNC heads on the EVO VIII and IX we knew it was a must to develop a head for the evo X. I wanted to share a bit of the process involved in the CNC porting process
I am going to show you a series of pictures in sequential order of the CNC process. each will be labeled with a corresponding number, 1-4. Below are the descriptions of each stage of porting all the way up to the final product.
1. - As cast by OEM, this the way your stock EVO X cylinder head would look
2. - CNC ported: Note the un-machined areas in both the port and the chamber. These areas will vary from casting to casting. In some castings a port wall or roof may be left un-machined. This is due to the acceptable tolerances for castings, which allows for a greater amount of deviation in port location and shape than the CNC machining process. During CNC machining, an exact copy of the port shape and size is machined into the casting regardless of the variations in the casting.
Of course, you could modify the CNC program to machine the un-machined areas. This approach would result in the CNC "look" in all the ports, on all the surfaces. The drawbacks is the "modified" port would result in a larger than desired port volume and / or a port shape that is not the same as the originally developed port.
With all of the above considerations, it is our approach to cut the developed and tested port shape into a casting along with lightly hand finishing the un-machined areas in. This is not only more aesthetically pleasing, but proven to obtain the exact results our customers expect. The results are verified on our Superflow SF-600 flow bench by comparing each heads flow numbers after machining to the results of the original "master port"
3. - Hand finishing and blending; this step cleans any transition lines left during the machining process and blends in the previously mentioned un-machined areas.
4. - Finished; All surfaces polished along with a valve job and blending
Now onto some pictures showing this.
Lets start with the bowl area on the head.
First is the stock bowl on the EVO X. Again this is what your stock head is like
Here is after the first stage of porting or Step 2 listed above
Here is the bowl after the next stage in porting, step 3 listed above
And finally the finished bowl, this would be step 4 above
Now lets move to the exhaust port on the EVO X head
First is the stock exhaust port, step 1 listed above
Step 2 on the exhaust port
Step 3 on the exhaust port
Finally the finished product WOW!! step 4 listed above
Lastly we move to the intake port on the EVO X head.
What gets me the most about this is the sheer increase in size of the port after we are done.
Step 1 the stock port
Step 2, after the initial CNC work
Step 3, Some more hand finishing
The final product, WOW is that a great deal bigger and smoother!
There you have it! An inside look at the CNC porting program here at AMS for the EVO X
Eric
Old Nov 16, 2008 | 08:12 PM
derekste's Avatar
Awesome stuff. Who did the original hand porting that the CNC is based off of? You guys don't have a CNC machine in house yet, do you?!
Are the valve guides installed in step 4? Do they not protrude into the port, even in stock form? If so, that is badass... wish my VW had that instead of the tapered valve guides I did as part of my P&P.
Old Nov 17, 2008 | 08:28 AM
uneedthis2's Avatar
Looks great, now lets see what kind of numbers this will produce!
Old Nov 17, 2008 | 08:34 AM
Evil Evolution's Avatar
This is a pretty big step towards makin some real power on the X. Do you guys have a HP goal you want to hit by spring?
Old Nov 20, 2008 | 10:38 AM
A how its made video
Old Nov 21, 2008 | 07:57 AM
Old Apr 6, 2009 | 07:53 PM
a1091156's Avatar
I must say, well done on reducing below 0.250" lift flow numbers. Not many people realise how little the valve open area is around that duration and that it is were reversion occurs.
AutoMotoSports
71
Oct 7, 2009 03:37 AM
Tim@AMSperformance
39
Sep 17, 2009 05:37 PM
AutoMotoSports
27
Aug 25, 2009 03:20 PM
AutoMotoSports
28
Mar 18, 2009 02:38 AM
Dan@AMS
13
Dec 6, 2008 06:33 AM
