Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Building a bullet proof 4b11 motor
Old Dec 29, 2008 | 09:23 PM
Cirrusly Evolvd's Avatar
I'm impressed, you guys are always innovating new products.
As for the naysayers, why are you even wasting your time typing? AMS is doing what real shops do: work with what they have and try to make it better. No one is disputing the difference between the 4G and the 4B. That's pointless....and so are posts about how you think this block isn't worth trying to build.
Old Dec 30, 2008 | 09:50 AM
homemade wrx's Avatar
Originally Posted by EricJ@AMS
I disagree. A ductile Iron sleeve is far superior to the bore surface in a cast iron block. Its stronger, cleaner, thicker, and can be bored over further once scarred or worn without risking its integrity.
I agree completely. I'm largely a subie guy (sleeves anyone) but grew up with 3tc's and have played with the 4g63 just a few times
Once a 4g63 starts cracking cylinder bores (which they do at very high cylinder pressures), it cannot be sleeved due to its design and you have to take extreme measures to support the backside of the cast bore.
I'll disagree that it can't be sleeved. It can be sleeved, similarly to a good old american iron V8.
sleeved 4g63 to have a safe cylinder wall thickness on a 86.5mm piston (2.4L)
bore spacing provided, another nicety of sleeving...bigger bores, which can lead to finding better charge/discharge coefficients too.
Old Dec 30, 2008 | 10:18 AM
Tim@AMSperformance's Avatar
I'll have to agree with Homemade wrx the 4g blocks can be sleeved. In fact in my personal car I sleeved the motor to play around with bore sizes etc. They worked great!!!
Old Dec 31, 2008 | 03:26 AM
Tvwj's Avatar
why dont you guys be like Honda make DART blocks.
Old Dec 31, 2008 | 05:45 AM
gt42r's Avatar
Hello,Tim.If you want to answer,what overall diameter sleeves do you suggest for the 4G63?Thank you and happy new year!
Old Jan 7, 2009 | 12:26 AM
wshihdnevo's Avatar
I love pics...
Old Jan 7, 2009 | 11:24 AM
Originally Posted by wshihdnevo
I love pics...
they do make for more fun in a thread
Just wish the 4G63 or 4B11 could handle my big Subie pistons
Sleeving out to 87.5mm on a 4G63 isn't unheard of...infact with a nice 94mm stroke and 6mm tighter compression height (than OEM piston), makes for a pretty sweet all around "2.3L" engine with some strong mid and top end power.
Old Jan 8, 2009 | 09:18 AM
Im not sure of the optimum bore size once a block is sleeved. I went .050 over and liked it. I cant compare this to anything else due to not experimenting with any other sizes.
Old Jan 8, 2009 | 03:25 PM
gt42r's Avatar
Thank you for the reply Tim.I meant the outside diameter of the sleeve,not the bore size.How much can I machine the block to install the sleeves?Thanks.
Old Jan 11, 2009 | 12:53 PM
DynoFlash's Avatar
Originally Posted by Mike@AwdMotorsports
Not knocking what AMS is doing by any means.. I feel the same though.. Closed iron block gives so much more peace of mind..
I respectfully disagree
The most powerful engines in the world run sleeves - top fuel drag cars
I have had a lot of success with my STI with sleeved blocks
Old Jan 11, 2009 | 12:56 PM
DynoFlash's Avatar
I agree 100%
Anyone who tries to make 1,000 whp with an Evo will discover the limits of the cast iorn block in a hurry
Small Block Chevy blocks have a similar problem
An Alum block with ductile sleeves is the ultimate performance combination for a variety of reasons including less weight
Old Jan 11, 2009 | 01:01 PM
DynoFlash's Avatar
Originally Posted by itsme4g63
Sounds like a good point, sleeved motors have the advantage in that area seeing as if the sleeve does happen to crack without damage to the block there is a possibility to press it out and refit it with a new one or a thicker one. When I read that a step is machined to keep the sleeve in place, that really shows engineering ingenuity, not just because it makes the most sense to do so, but alot of large manufacturers apply this theory as well for press fit assemblies. Am not sure bout this but most likely the sleeves are heat treated to improve strength then honed out to fit the pistons and eliminate any material expansion created via aforementioned process, a cast aluminum block fitted with these sleeves might proove to be just as good or superior taking into factor if the 4b11 aluminum cast might be brittle (or the sleeves its fitted with, which can also be caused via improper heat treating where internal cracks are prematurely induced which can get larger based on abuse). But bigupps to ams for thinking ahead and creating a well built motor. Seeing as erl are great at making honda big blocks, I'm pretty sure their sleeves will work flawlessly with the new mitsu motor.
The steeped sleeve is not a new concept - Darton has been using them for some time
With a proper sleeve install they are not going to drop.
I have beat my STI so hard and with so much boost and the sleeves were the most reliable aspect of the motor since day one
As with any other modification, there are right ways and wrong ways to do a sleeveing job. Who is doing the sleevng is very important. You can't say that sleeving is bad just becuase certain Honda guys may have had problems.
Many V8 guys have had no problems.
Many STI guys have had no problems
My favorite Nissan V6 3.5 guys have had no problems
Old Apr 13, 2009 | 10:54 AM
brndn23's Avatar
So is this sleeving only for the evo x (4B11t), or for the n/a 4B11 as well?
Old Apr 13, 2009 | 12:44 PM
Colt4g63's Avatar
ERL is litterally 1 mile up the street from my house if that.... I have some friends that work there. I might have to go check this out in person.
Old Apr 13, 2009 | 12:55 PM
Billy@EnglishRacing's Avatar
If you like or dislike sleeves it is still going to be necessary on high HP 4B11's. Due to the fact that the motor is going to be coming out in alot of different cars it is time to embrace them or be left behind.
Tim thanks for starting this thread it is very nice to see your progress.
