Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
What torque spects for AMS 2.3 ?
Old Apr 12, 2009 | 07:03 PM
shunderwunder's Avatar
I need the torque specs for an AMS 2.3 stroker kit. Mainly the rod bolts & crank bearing nuts. Are these the same as the stock torque specs which I already have or are they specific to this kit?
Old Apr 12, 2009 | 07:32 PM
Hikaru's Avatar
Dude, you're tearing down the motor? Hope all is well with it. Better than the cams.
Old Apr 13, 2009 | 08:15 AM
Andrew@AMS's Avatar
Hey Shunderwunder,
The rod bolts get torqued to 45 ft. pounds and the main studs get 60 ft. pounds. Make sure to torque the main studs in sequence. Please let me know if you need further information.
Old Apr 13, 2009 | 04:33 PM
Yes I did & everything looks fine on the bottom end, so the short block is good. I just wanted to make sure there wasnt something in the oil that caused the same issues elsewhere.
Originally Posted by Andrew@AMS
Hey Shunderwunder,
Thanx a ton. I didn't think they were the same as stock.
