*AMS Product Release* AMS Piston Ring Squaring Tool
The AMS Piston Ring Squaring Tool is a must for anyone building or replacing a motor that requires file fitting the piston rings. To insure proper measurements, you must set your ring squarely inside the bore. The problem with doing this by hand is you can never insure that the ring is properly square which can lead to improper measurements. The AMS Piston Ring Squaring Tool takes all your worries away! Due to the stepped edge of the AMS tool, you can rest assured that the rings will be square to the cylinder bore and you will get a precise measurement every time. This black anodized double sided tool will fit a number of engines. One side will fit 85mm to 87mm and the second side will fit 87.5mm to 88mm. This should easily cover any 4G63, 4G64, or 4B11 motor out there!
Applications
- Mitsubishi 4G63 / 4G64
- Mitsubishi 4B11
- Engines with bore size of 85mm-87mm
- Engines with bore size of 87.5mm-88mm
Price: $89.99
Click Here to purchase this product.
