Torque Solution 255lph Fuel Pump: Mitsubishi Evolution X 2008+
https://www.awdmotorsports.com/Produ...TS%2DEVX%2D255
Torque Solution Fuel Pump 255lph
Applications: Mitsubishi Lancer Evolution 2008+
The Torque Solution 255lph Fuel pump is a direct factory replacement of your oem fuel pump for your 08+ WRX & Sti, Evolution X, R35 GTR & 2006+ Civic Si. No wiring, No grinding or chopping up your factory fuel pump housing. This pump allows you to convert back to stock without ever knowing you had an aftermarket pump in there. This new compact design makes installation a breeze. All of this while flowing an astonishing 255lph@40psi and is fully compatible with Race Fuels & E-85!! These pumps also feature a 3 year warranty to the original purchaser as well.
•Flows 255lph@40psi
•Compact Design
•Direct Fit
•3 Year Warranty
•Made in USA
