Ethanol gas???
Old Dec 18, 2004 | 06:41 PM
dlo's Avatar
dlo
Ethanol gas???
I've heard that ethanol blended gas isn't good for your engine, although I've heard no specific problems it causes. Is this just a myth or is there some truth to it? I use it all the time because here ethanol blended gasoline is the same price at 90 octane as regular gasoline at 87 octane.
Old Dec 30, 2004 | 11:24 PM
EdT's Avatar
EdT
Exclamation
As long as the percentage of ethanol is 5%-10% you are alright, anymore and it will start softening your rubber hoses and rust your internal engine parts. A good trick is to use ethanol on one fill-up and regular gas on the other and keep doing this to re-lubricate the hoses and engine.
Old Jan 11, 2005 | 04:35 AM
alleggerita's Avatar
Ethanol on a modern engine is a non-issue. On older vehicles it will potentially eat the rubber depending on the type used.
However, ethanol while increasing octane will not give much power. Generally, a gasoline formulated with heavier aromatic compounds will have a greater energy value and produce more power. If you use a large amount of ethanol in gasoline you may potentially have to change fuelling (eg mixture).
Ethanol is great for passing emissions testing though.
