piggy help
just getting piggy info. What is the v.2 piggy? is it the same one from rrm and will it go on a 04 stick ralliart. If I do get it do I need the program to instal it or can the mits service do it? Thanks
If you buy the V2 Piggyback it will work on your standard Ralliart.
V2 is because it is the second version of them, the first one used a Vacume line as well as being wired into your stock ECU. The V2 Only gets wired in.
Install it yourself, although a piggyback may void some of your warrinty so I would discuss it with your dealer first. It comes with detailed instructions and as long as you know how to solder wires properly it shouldnt be difficult. If you don't know how to do this then find someone who does and ask them.
What about it wont work? He is the sole distributer of them so if he says it won't work it problaby won't. Although I don't see why not, as long as its a RalliArt piggyback it should be fine.
