daytime running ligh question... (08 Lancer GS41)
Old Jan 31, 2008 | 10:38 AM
GS41_Lancer's Avatar
Hello there,
i got my HID low beam installed but found that the daytime running light also utilize the low beam......-_-""
as a result, i have to turn HID on even during daytime to ensure proper voltage flowing into the low beam....
do you guys have any easy way to modify the daytime running light to the high beam...? (which most of the other vehicles do if they have high-low beam separate.......)
Thanks in advance!
Old Jan 31, 2008 | 01:38 PM
wazzuuuup's Avatar
run them of the side markers, it will solve all your issues
Old Jan 31, 2008 | 02:11 PM
run the daytime running light off the side markers?
i am not too sure how you can do that....?
Can you explain in a lil detail please?
Old Jan 31, 2008 | 02:29 PM
wazzuuuup's Avatar
run the hid's off the side markers.
this will give you the hid's on the first and second click, when your switch is off you will have no drl's, you have no choice, you have to eliminate the drl's all together, hid's will not work with them.
Old Feb 1, 2008 | 06:47 AM
so there is no way to make the drl running on the high beam...?
umm... that's not a nice design from .....
Old Feb 4, 2008 | 07:39 PM
homieG's Avatar
i ran my DRL to my fogs, thats another option u could use. the fogs act as ur DRL's and u low beams work on ur fogs switch. was wierd at first but kinda like it like that. love the only fogs look too sometimes!
