what oil do you use?
Old Apr 16, 2008 | 07:19 PM
Oil Doc's Avatar
If it is an EVO.... 5W-20 is not recommended... Fine for a Lancer...as long as it is a Daily Driver and not beat on..
Royal Purple Engine Oil shears back way to quick...
Doc
Old Apr 16, 2008 | 07:21 PM
Import Junky's Avatar
whatever my factory manual says. I think it's 10w-30 Mobile 1
Old Apr 16, 2008 | 07:26 PM
nwevo_8's Avatar
ive used royal purple 10-30 for over 30k and its good stuff
Old Apr 16, 2008 | 07:39 PM
Oil Doc's Avatar
How often do you change your oil ?
Royal Purple shears way to quick....
Doc
Old Apr 16, 2008 | 08:54 PM
ZeroFighter83's Avatar
Hey Oil doc, what's the best Amsoil to use for track duty for an Evo?
Old Apr 18, 2008 | 07:51 AM
Oil Doc's Avatar
If your bottom end is stock or running stock clearances, AMSOIL SSO 0W-30
If this is a vehicle that strictly sees heavy track use and/or the bottom end has been loosened up, I would go to AMSOIL TRO 20W-50 Racing Oil.
Doc
Old Apr 18, 2008 | 08:01 AM
Doc
Thanks Doc!
How do these Amoils oil compare to Motul's 8100 or even 300V's?
Old Apr 18, 2008 | 08:13 AM
Oil Doc's Avatar
Thanks Doc!
Depends on the weight being used... If we are talking the 20W-50, there are several oils including AMSOIL that are better than the Motul
In a 10W-40... AMSOIL and Mobil 1 EP out perform the Motul.
Is the Motul a good oil ? Of course it is..., You definitely won't hurt anything running it...
Doc
Old Apr 18, 2008 | 08:51 AM
Doc
Haha, I'm waiting for the "but........"
Old Apr 18, 2008 | 09:27 AM
Oil Doc's Avatar
No "But" when it comes to Motul.... We are not talking Royal Purple here...
Although AMSOIL does outperform Motul, Motul is quite a respectable oil.
Motul prefers to use a full Ester Base stock where AMSOIL and some others went to a PAO with Esters years ago. There are a few drawbacks to a full Ester Based product and it is general consensus the a PAO with Esters is better.
If we really want to get down to it.... It doesn't make a difference in the Base Stock... Over All Performance is what really should be looked at.
Doc
