Hybridr.com
Old Dec 9, 2008 | 04:53 PM
  #31
blancy612's Avatar
u kno wat i might just get this! with my lip it'll b perfect! =) hows the ride?
Old Dec 10, 2008 | 02:15 AM
  #32
dD Spikey's Avatar
Originally Posted by brads09lancerGT
I don't know if this is what is causing your problem but check out this thread post #39. https://www.evolutionm.net/forums/sh...=369830&page=3
I've heard of lots of people doing this.
I'm doing lowering springs this spring and I was pricing things out. My local said that they would adjust the camber bolts for me when they do my wheel alignment after I install the springs. It's included in the $80 for the wheel alignment.
Thanks for posting that up!
Old Dec 10, 2008 | 02:18 AM
  #33
dD Spikey's Avatar
The springs are a bit stiffer than stock, so it will be a bit bumpier, but nothing that is going to jar your kidney loose. And you'll notice a big reduction in body roll when cornering, and way better steering response.
Old Dec 10, 2008 | 02:19 AM
  #34
dD Spikey's Avatar
Originally Posted by johntango
Now i'm really starting to regret touching my suspension. What's up with **TIK TIK TIK TIK SOUND ON SLOW TURNS??? For sure not the wheel bearings, not the drive shaft, sounds like coming from the Strut mounts. Help??? Please and thank you.
Did you check out the post above? Hopefully that helps fix your situation. If not, PM me.
