interior stock switches box...any that fit?
The switched that you can order from Mitsu don't actually have anything useful inside. Just a pcb, There are ment to enable something in the ECU to enable a feature on the car. Say You want lights to turn on, then you press the button. ECU senses that the button has been pressed and ECU turns on the lights. NO actual Functionality....Unless you crack it open and mount and wire your own toggle switch.
This is what I did, but its way costly. $45 for something that you still need to modify to get to work.
Theres the ASC from the Evox. The TRC from the Galant and the Fog lamp from the Outlander. they all fit in the slots
