Gated Shifting Plate Lancer
Old Jan 28, 2009 | 03:26 PM
stone604's Avatar
I was just wondering if there were any aftermarket parts for a gated shifter for the 09 Lancer. i know you can make one but i technically dont know how to do that ..i had someone explain it to me doesnt seem too hard..but why try to make something when it can be bought
anyone know of any companies selling this part?
Old Jan 28, 2009 | 06:07 PM
ambystom01's Avatar
Why would you want to turn a normal shifter into a gated shifter?
Old Jan 29, 2009 | 02:49 AM
cih's Avatar
cih
i dont think the distance between gears is long enough for this to work.
Old Jan 29, 2009 | 09:05 AM
rontam90's Avatar
theoretically if you cut a piece of metal which can match up the shift pattern then it can be possible.
You would need to remove your shift boot and might need to shorten / lengthen your throws
but it seems a bit pointless because you wont get that stiff and precise feel that comes with a proper gated shifter (like the ones in lamborghinis ferraris etc).
Old Jan 29, 2009 | 11:13 AM
stone604's Avatar
i just like the look of them rather than the boot. and i am new to manual transmission so if i look down i can see which gear i am in :P i know im a newbie lol .. gotta learn somewhere.
so i dont really need the feel of the shifter more of the look and convienece and style of course.
Old Jan 29, 2009 | 11:17 AM
ambystom01's Avatar
The shifter isn't as stiff or precise as found in Ferraris or the Ford GT, unless you want basically a giant hole with metal trim, I don't see how it could work. You'd constantly be catching the shifter on the plate. If you just want to know what gear you're in, put some stickers on your centre console.
Old Jan 29, 2009 | 11:42 AM
stone604's Avatar
while i have been driving i havent missed a gear yet...good thing
i also like the look fo the gated shifters but i guess frabricating my own is the only way. and all the measurements need to be precise.. ill look more into it and maybe i can make it work down the road.
Old Jan 29, 2009 | 12:15 PM
cih's Avatar
cih
if you take exact measurements you'll be building yourself a plate with a rectangle cut into it.
Old Jan 29, 2009 | 04:48 PM
stone604's Avatar
saying its one big hole,lol, in a plate ..?
Old Jan 29, 2009 | 07:04 PM
wazzuuuup's Avatar
I think you nailed it
Old Jan 29, 2009 | 07:14 PM
stone604's Avatar
lol well dam. ill still look at it maybe i can make it work
Old Jan 29, 2009 | 07:17 PM
localtoys73's Avatar
try to find a machine shop i dont think it will be that hard to make
Old Jan 30, 2009 | 01:40 PM
stone604's Avatar
i will try and muck around with some things i will letyou guys know ...after i get my car tho :P
Old Mar 5, 2009 | 02:12 PM
Cranky's Avatar
Since you're new to manual, here... I used this shifter knob to learn the gears.
Just remember...
use R when you're facing the dealer's window and 1 when it's behind you. Don't want no oops moments! If you're facing away from the window, squeek those tires a little, as a g'bye to the dealer.
Just kidding lol
Old Mar 9, 2009 | 03:39 PM
stone604's Avatar
lol i stalled pulling out of the lot :P when i had my car but im fine now little opps moments but im just trying to be too slick:P
