Gts owners+winter tires
Old May 27, 2009 | 05:59 AM
laflsyl10's Avatar
Those who had a gts over last winter, was was the smallest winter tires you guys could put on.
Thank you
Old May 27, 2009 | 06:38 AM
evo_soul's Avatar
this is a repeat topic... for the GTS's But since you have a RalliArt I am not sure. I think you should ask in those forums. But visually there is almost no difference between the GTS wheel + tire vs. the RalliArt.
16" is the smallest tire rim,
Old May 27, 2009 | 09:28 AM
Billy's Avatar
Generally speaking the smallest tire you can fit will depend on your wheels.
If you're not keeping your stockers for winters then the factors with net new rims that affect fitment mostly relate to brake clearance.
Smallest diameter
Narrowest width
Preferred offset (bearing life vs. wider track)
I would look for specific makes/models of rims that have been proven to fit with your brake/hub/body/fender/alignment/suspension for a carefree choice.
Old May 29, 2009 | 01:55 AM
contagius's Avatar
just put factory sized tires on. I got Nokian Hakka 4's w/ studs for winter and those things will climb trees.
Old May 29, 2009 | 09:12 AM
vivroy's Avatar
Hi,I am intersted in getting this,if its possible can you plz share more information on that, like where you can get it and what is it ,how much it cost?
Thanx in advance,
vivroy
Old May 29, 2009 | 06:55 PM
contagius's Avatar
Thanx in advance,
vivroy
I ordered them online. They were expensive, but they keep you out of the ditch.
