~~ Scan tool testing on the lancer
I need someone with a 5 speed lancer 08 or a 2009 would be even better. If you live in the brampton area and can pop by, I would like to test out a new ScanTool. The advanced modual should be here soon, that will allow me to do anything and everything under the sun in terms of sensors and also initiate comands.
let me know if you have any time , PM me :) did i mention free coffee at tim hortons lol haha :) and a donut or two :) Cheers |
i work in sauga, so prolly could pop by one day....as long as i can drive back in one piece! ;) hahahaha. let me know when.
does the coffee include an iced capp supreme?!?! hahaha
I promise not to trigger the self destruct code. haha but honestly I have been playing around with it on my car just looking at the basic sensor list and its pretty good amount of data here. With the advance modual it allows me to initiate active commands :) frigging cool. haha
just look at all the sensor detail for the CVT transmission sensor set alone TransmissionCVT1400SeriesCAN Sensors commands top ABS Actuation Signal Acceleration/Deceleration Value Accelerator Position ASC Actuation Signal Brake Switch CVT Oil Temperature CVT Oil Temperature Sensor Signal Engine Revolution Engine Torque (After Correction) Gear Position (SP Mode) Idle Switch Signal Indicator D Output Indicator DS/L Output Indicator N Output Indicator P Output Indicator R Output Indicator SP Mode Output Inhibitor Switch Input Torque Line Pressure SOL. Monitor Current Line Pressure SOL. Output Current LU Solenoid Monitor Current LU Solenoid Output Current LU/SEL Changeover SOL. Monitor LU/SEL Changeover SOL. Output Paddle Switch (Down) Paddle Switch (Up) Power Supply Voltage Primary Pressure Primary Pressure Sensor Signal Primary Speed Primary Speed Sensor Signal Real Engine Torque Real Step Real Variable Speed Ratio Real Vehicle Speed Secondary Pressure Secondary Pressure Sensor Signal Secondary PRS. SOL. Monitor Current Secondary PRS. SOL. Output Current Secondary Speed Secondary Speed Sensor Signal Select Switch (Down) Select Switch (Up) Shift Position Slip Revolution SP Mode Switch Stepper Motor Coil A Stepper Motor Coil B Stepper Motor Coil C Stepper Motor Coil D Target Line Pressure Target LU Differential Pressure Target Primary Speed Target Secondary Pressure Target Step Target Variable Speed Ratio TCL Actuation Signal Torque Ratio Vehicle Speed (Inference) this is a must for any boost turbo CVT project |
im down....see if i can make my car faster! hahah and better on gas at the same time.
let me know when. |
i am studying the active codes to see what can be done. and ya I will get you an ice cap...
