~~ Scan tool testing on the lancer
Old Jun 25, 2008 | 11:28 AM
evo_soul's Avatar
I need someone with a 5 speed lancer 08 or a 2009 would be even better. If you live in the brampton area and can pop by, I would like to test out a new ScanTool. The advanced modual should be here soon, that will allow me to do anything and everything under the sun in terms of sensors and also initiate comands.
let me know if you have any time , PM me
did i mention free coffee at tim hortons lol haha and a donut or two
Cheers
Old Jun 25, 2008 | 11:29 AM
homieG's Avatar
i work in sauga, so prolly could pop by one day....as long as i can drive back in one piece! hahahaha. let me know when.
Old Jun 25, 2008 | 11:30 AM
homieG's Avatar
does the coffee include an iced capp supreme?!?! hahaha
Old Jun 25, 2008 | 11:46 AM
evo_soul's Avatar
I promise not to trigger the self destruct code. haha but honestly I have been playing around with it on my car just looking at the basic sensor list and its pretty good amount of data here. With the advance modual it allows me to initiate active commands frigging cool. haha
just look at all the sensor detail for the CVT transmission sensor set alone
TransmissionCVT1400SeriesCAN Sensors commands top
ABS Actuation Signal Acceleration/Deceleration Value Accelerator Position
ASC Actuation Signal Brake Switch CVT Oil Temperature
CVT Oil Temperature Sensor Signal Engine Revolution Engine Torque (After Correction)
Gear Position (SP Mode) Idle Switch Signal Indicator D Output
Indicator DS/L Output Indicator N Output Indicator P Output
Indicator R Output Indicator SP Mode Output Inhibitor Switch
Input Torque Line Pressure SOL. Monitor Current Line Pressure SOL. Output Current
LU Solenoid Monitor Current LU Solenoid Output Current LU/SEL Changeover SOL. Monitor
LU/SEL Changeover SOL. Output Paddle Switch (Down) Paddle Switch (Up)
Power Supply Voltage Primary Pressure Primary Pressure Sensor Signal
Primary Speed Primary Speed Sensor Signal Real Engine Torque
Real Step Real Variable Speed Ratio Real Vehicle Speed
Secondary Pressure Secondary Pressure Sensor Signal Secondary PRS. SOL. Monitor Current
Secondary PRS. SOL. Output Current Secondary Speed Secondary Speed Sensor Signal
Select Switch (Down) Select Switch (Up) Shift Position
Slip Revolution SP Mode Switch Stepper Motor Coil A
Stepper Motor Coil B Stepper Motor Coil C Stepper Motor Coil D
Target Line Pressure Target LU Differential Pressure Target Primary Speed
Target Secondary Pressure Target Step Target Variable Speed Ratio
TCL Actuation Signal Torque Ratio Vehicle Speed (Inference)
this is a must for any boost turbo CVT project
Old Jun 25, 2008 | 12:02 PM
homieG's Avatar
im down....see if i can make my car faster! hahah and better on gas at the same time.
let me know when.
Old Jun 25, 2008 | 12:24 PM
evo_soul's Avatar
i am studying the active codes to see what can be done. and ya I will get you an ice cap...
Drive02Lancer
Lancer Engine Tech
16
Aug 8, 2019 11:16 AM
vaqusis
56
Sep 29, 2017 08:35 AM
no1_alpha91
Nov 8, 2014 08:12 AM
lancer0220
08+ Lancer Show / Shine
12
Apr 22, 2011 01:43 PM
joeyfingers
Sep 12, 2006 02:58 PM
