AP load timing (load)
Old Sep 21, 2011 | 09:24 AM
iowa_guy's Avatar
I am looking at my logs and the AP has a column called load timing (load). Is what they are using for the load?
So I refer back to my tables in my rom for RPM and the LOAD at that RPM to make changes to the tables??
Just want to make sure I am looking at the right things...
in a nutshell...
You look at RPM and this Load Timing and if you have let's say knock at a certain RPM and Load in your log...you can go back and tweek those cells (as well as those around it) to smooth it out?
Old Sep 21, 2011 | 12:58 PM
Kracka's Avatar
Correct.
