Help with AP Datalog
Old Oct 18, 2011 | 01:27 AM
GeeDubz's Avatar
Can someone please help analyze my datalog and give me some suggestions? I have '08 Evo X GSR, Calif. Spec. with AEM intake, Cobb Hard Pipe Kit (UICP & LICP), Greddy catback exhaust. (datalog attached is a .CSV file in the zip because they don't allow CSV files to be uploaded)
Thanks!
File Type: zip
Old Oct 22, 2011 | 12:54 AM
GeeDubz's Avatar
I've switched back to AP firmware v1.6.3.2-1262 and now using "Stage1+AEM 91 GSR v108" map. Attached is the datalog in PDF.
Don't mind the highlighted cells in red; they are for my own reference so it's easier for me to locate the extreme numbers. I've noticed some really high numbers for TLFT & STFT but usually only at low and sometimes at mid rpms and never at the same time when at WOT. I don't know if this is a concern I should be worried about.
File Type: pdf
Old Oct 23, 2011 | 04:05 PM
guswaym's Avatar
you should update your accessport and log with knock sum
Old Oct 24, 2011 | 01:09 AM
GeeDubz's Avatar
I don't have "knock sum" on the latest logs because I'm currently using AP firmware version v1.6.3.2-1262; this version only has "knock retard". If I use AP firmware v1.6.5.0-2223 beta, then there is a "knock sum" monitor.
Old Oct 24, 2011 | 04:14 PM
GeeDubz's Avatar
magj
Jun 19, 2015 06:29 PM
acm123
May 6, 2015 02:19 PM
browningderek
Jan 7, 2015 06:10 PM
Rall1boy
15
Aug 16, 2012 06:42 AM
RSGuy
AEM EMS
Jun 14, 2011 06:21 PM
