new to the cobb ap
Old Dec 8, 2011 | 12:23 AM
mike2010X's Avatar
new to the cobb ap
so today i got my cobb ap followed all directions and installed correct map, then for a little test run, i noticed my rpm jumps between 1-2k before dropping and staying around 700rpm while stopped using the live data monitor. is this normal? im currently running the stage 1 for stock vechicle.
Old Dec 8, 2011 | 08:41 AM
mike2010X's Avatar
so everything seems to be ok this morning no spikes in RPM at idle, constant 900 range for the RPM
Old Dec 8, 2011 | 08:52 AM
Spazpilot's Avatar
Bet the ECU had to relearn the conditions. Same as if you were to disconnect your battery
Old Dec 8, 2011 | 10:10 AM
mike2010X's Avatar
thats what i was thinkin after my drive into work this morning, i called cobb to talk to them about it, they told me to check the vacuum lines, said its a pretty common issue that most people run across with it popping off, so i double check that before leavin work today.
Old Jan 16, 2012 | 03:24 PM
bmxking45's Avatar
how does the car feel? I too am looking at getting a cobb ap as my first mod. Just curious to see if you noticed a fairly substantial difference
Old Jan 17, 2012 | 05:48 PM
rodeopunk_je87's Avatar
It's normal to get some wierd idle but have you done this yet?
https://www.evolutionm.net/forums/sh...=444277&page=1
