Boost spike after shift
Old Jan 8, 2012 | 04:31 PM
Jookies's Avatar
So I was doin some logging lately ( I'm on stage 2 Cobb ap with a tbe with a testpipe, intake, and uicp) and the 3rd gear pulls look great( 24.5-25.5 with little to no knock) though right when I shift to 4th and go wot again, the logs show me spiking to almost 29 psi for a few frames ( starts to drop then) does anyone else have this issue? I'm hesitant to go LWG since my 3rd gear pulls are at target boost... Any advice?
(p.s there is no knock when it spikes)
Old Jan 8, 2012 | 04:56 PM
Kracka's Avatar
I'd honestly say it's fine; my guess is it won't spike as high once the temps warm back up. Have you considered getting a protune?
Old Jan 8, 2012 | 05:03 PM
Jookies's Avatar
Haha cool, and I have considered, it's just I still plan on getting an intercooler, and also just cant afford any of it right now haha.
But you're saying it's not dangerous?
Old Jan 9, 2012 | 07:57 AM
Kracka's Avatar
I'm not going to say it's perfectly safe, but a quick spike in cooler weather with no knock isn't something I'd be overly concerned about, especially on a relatively stock car.
Old Jan 10, 2012 | 02:26 PM
HPEVOX's Avatar
Mine does the same thing. Been doing it for a year or so with no issues. Grimmspeed 3 port and a pro tune should solve it if you're concerned though.
Old Jan 12, 2012 | 06:34 AM
Jookies's Avatar
Meh, there's no knock, so im not worried haha. Thanks for the replies!
Old Sep 22, 2014 | 08:17 AM
Hiboost's Avatar
I'm seeing a 3-4 psi boost spike on 4th-5th upshifts and 5th-6th upshifts. The only work around that automatically keeps things safe is to reduce boost on my "high gear" tables which only effect 5th and 6th gears but that takes a good 20-30 whp away from my 375 whp NARRA tune which I sorely need to stay competitive. The other work around is to lift on upshifts into those high load gears but that is really distracting when concentrating on maxing out cornering speeds.
I'm going to try and turn on error correction to only allow downward correction and make sure my target loads are lower than actual between gear shifts.
I'm also going to raise my "lower bound ignition timing" tables so there is less timing drop during upshifts given that load usually spikes slightly and report back on results.
Ferp
Mar 11, 2017 09:50 AM
Jaraxle
Aug 12, 2016 08:31 PM
Kapoosh1
28
Oct 13, 2009 03:18 PM
racer135
Jul 19, 2008 10:48 PM
Chamama
Feb 28, 2008 05:57 PM
