PLEASE HELP! WOT Jerk/Bump As Approaching Redline in 3rd
Old Jan 22, 2012 | 08:18 AM
rodeopunk_je87's Avatar
2011 Evo X GSR
Odometer Reading: ~1,200 miles
Outside Temperature: ~10 degrees
Cobb Stage 1 93 Octane Tune only
http://youtu.be/ioxrk5kc_Ug
Hey guys,
So last night, I decided to take the car out and do some spirited driving. After driving around for a little while, I went to a back road and did some WOT pulls. As you can see in the video, I went from 1st to 2nd to 3rd, but then in 3rd as I was approaching redline (between 6-7K), all of a sudden I felt/heard a jerk/bump and the RPMs stuttered. I thought I may have hit a patch of ice or snow so I tried it again. I was able to replicate this 3 times in a row. Third time I recorded it. I immediately went home, flashed the car back to stock and call a couple of people about it.
I then picked up my brother-in-law who has a 9 and we went out to see if I could duplicate it and maybe diagnose it. Well, long story short, I could not replicate it anymore. I then flashed the car back to stage 1/93 octane, and still could not replicate it. I ran the Cobb AP to monitor performance while we tried to replicate it, and my peak boost was 25PSI, and I had no trouble codes.
My buddy then called and had me look at my fuse box and we confirmed that I don't have the updated fuel relay. We chalked it up as this being it, and I'm going to stop by AMS tomorrow and pick it up, but I wanted to see what other people on here had to say about it? Any idea what it could be? I already zip-tied that little hose under the engine cover (near the dipstick) that is known to pop off, and I've only launched the car twice since I got it.
Old Jan 22, 2012 | 09:44 AM
guswaym's Avatar
looks like fuel cut its cold out side lol
Old Jan 22, 2012 | 10:27 AM
Really? Are they common at these temperatures?
Old Jan 22, 2012 | 06:41 PM
NateDaJew's Avatar
Change the relays and go to the dealership.
Old Jan 23, 2012 | 05:06 AM
I get the relay suggestion, but why the dealership?
Old Jan 23, 2012 | 08:04 AM
NateDaJew's Avatar
I figure she still be under warranty. Let them pay for the relays
Old Jan 23, 2012 | 08:07 AM
Kracka's Avatar
Fuel cut because it's cold outside, you're probably over-boosting which is very common in temps that low. Give the LWG version of that map a try and my guess is that solves your issue.
Old Jan 23, 2012 | 08:31 AM
Overboosting? Do you think I did any damage?
Also, I don't believe I saw an LWG version since this is still Beta map
Old Jan 23, 2012 | 08:33 AM
True...but I rather not go through the whole hassle of making an appt. (i can only go on weekends) and waiting for them to check it, the replace it. I already bought the relay from AMS for $15.
Old Jan 23, 2012 | 08:12 PM
Kracka's Avatar
No damage, that's why fuel cut is programmed the way it is; basically acts as a limit. Talk to BakaUnchi, he should be able to set you up with a cold weather LWG map.
Old Jan 24, 2012 | 05:10 AM
Thanks!
Old Jan 28, 2012 | 03:38 PM
guswaym's Avatar
try switching to the 91 octane map but keeping 93 in the tank
Old Jan 28, 2012 | 04:00 PM
philamthebest's Avatar
With the cold weather we have been having in illinois lately, the fuel is cutting. Also is your boost spiking? Get a relay and you should be good.
Old Jan 28, 2012 | 07:51 PM
guswaym's Avatar
the relay isnt a magic fuel cut disabler i have the relays and when it gets cold i spike and cut and im pro tuned you need to have a map with lower boost ie lwg map suggested uptop to compensate in the temp changes..
Old Jan 29, 2012 | 06:31 AM
Hey guys,
Spoke to Cobb Tuning last week, and completely forgot to update the thread. They saw the video and said I was indeed overboosting due to the lower temps. They recommended that I replace the fuel relay and switch to LWG software in lower temps..
However, where can I find this LWG software? I thought it would be on my AP but I don't see it. I reached out to them on FB Friday night but they haven't replied.
I know I have an '11 so it's still in Beta, but does that mean they don't have LWG maps yet?
