2011 GSR Cobb Stage 2 Map Log
I just recently installed the Cobb AP and loaded the 2011 GSR Stage 2 Cosworth ACN91 Map. My setup is a 2011 GSR with ETS intake and Depo racing UICP, and everything stock. I was told to use the stage 2 map with my mod and it should be OK. Can someone please help me take a look at this Data Log to confirm? (I don't want to jump on this without know if I am running lean, knock like hell) Thanks!
http://www.mediafire.com/?429zc4c67aubwrj
but you need some assistance in how to log
you need to configure the logger to log the items we need
rpm
load
boost
knock
ignition timing
wdgc corr
ltft used
MAF V
IDC (injector duty cycle)
then drive around a bit (20 min) @ cruising speeds logging
then end the log and re log a few 2000-7000 pulls in 3rd gear
You already did the first part now do some 3rd gear pulls
