help!!!!
Old May 22, 2012 | 04:38 PM
3000GT-GTO's Avatar
Have you tried swapping out the fuel pump relay with the highbeam relay ?
Old May 22, 2012 | 04:49 PM
egokiller's Avatar
No the car is brand new didn't touch relays
Old May 22, 2012 | 04:53 PM
egokiller's Avatar
what does the relays do? im starting to think its just a sensor
Old May 22, 2012 | 05:38 PM
3000GT-GTO's Avatar
Bad fuel pump relay will causes Lean condition at wot, try it first and see if theres a difference. Swap the High Beam relay with the fuel pump 1 min job and you will know if its the relay.
Old May 22, 2012 | 06:29 PM
egokiller's Avatar
Where are the relays found?
Old May 22, 2012 | 06:36 PM
egokiller's Avatar
Never mind found it dumb question
Old May 22, 2012 | 07:18 PM
egokiller's Avatar
I tried that but same thing is happen
Old May 23, 2012 | 11:49 AM
3000GT-GTO's Avatar
Flash back to stock to test and if AFR still reads high probably sensor
Old May 23, 2012 | 04:06 PM
egokiller's Avatar
I switched it back to stock. I ordered the sensor it's coming friday
Old May 23, 2012 | 04:32 PM
Kiartiger's Avatar
I had a similar problem with my 02 lancer....it came down to one of my injectors was not closing so it would keep constant fuel going in. This may not be the case but if your wiring test fails for the sensors then i would try to test the injectors
Old May 23, 2012 | 08:32 PM
egokiller's Avatar
i belive its the sensor for my wideband watch the video on page 1 and i could not test the sensor because it did not go full lean
Old May 29, 2012 | 12:33 PM
Vivid Racing's Avatar
You never answered me...
You're running the AEM gauge AND the AEM sensor, correct?
And some new questions:
When you turn the key to ON, without starting the engine, what happens? Does it eventually go lower and lower until it reads "---"?
Old May 29, 2012 | 03:35 PM
egokiller's Avatar
my bad yes it the aem gauge and sencor and no it goes lower but never ---
Old May 31, 2012 | 01:11 AM
dozer808's Avatar
Is your AEM new or used?
Old May 31, 2012 | 01:24 AM
dozer808's Avatar
You could also just check you plugs to see if your lean or not.
