Newbie cobb question
Old Mar 7, 2013 | 02:40 PM
electricman's Avatar
Is anyone keeping there cobb plugged in 24/7 or rigged something up for power wise
Old Mar 7, 2013 | 03:00 PM
RallySport Direct's Avatar
Silver Sponsor
Personally I have not seen anyone have it hard wired in if that is what you are asking about and most people don't leave them out 24/7.
The AP is made to be removable to put away so that it is not something always sitting out that could catch a thief's attention for example or be in the way. It is a great tool for when you need to check thing and do tuning, but probably not worth keeping out and up the whole time.
Let me know if you have any other questions
Thanks,
Dallin
Old Mar 7, 2013 | 03:05 PM
MisterHappy's Avatar
Have a couple friends that have them set up to be plugged in each time them drive their cars so they can be used for boost gauges. They do unplug every time they turn off the car because it does stay on as long as it is plugged in and will either burn into thier screen or drain the battery.
Old Mar 7, 2013 | 06:24 PM
mshilto89's Avatar
I normally only plug mine in when driving and just to monitor knock and boost levels to make sure my motor isn't going to implode.
Old Apr 3, 2013 | 03:27 PM
Maps
Ok I just did the update today and installed the stage 1 1.08 map on my cobb before I was running the stage 1 mrv 301 can anyone tell me what the newest version is and also what I should run for my stock 93 car with a k&n drop in
Old Apr 3, 2013 | 05:02 PM
Should be v400 i believe. Run 93 stage 1 stock box.
Old Apr 3, 2013 | 10:41 PM
btack's Avatar
Probably not a good idea to leave it in all the time. How do you like it so far?
I always use mine as a boost gauge when I drive but put it away when I park
Old Apr 4, 2013 | 03:51 PM
Decided not to keep plugged In all the time. Also downloaded the v400 but shows in my map list but when I push on it to install kicks me out to the beginning anyone else with this issue
Old Apr 4, 2013 | 03:53 PM
Make sure you have the right year and all that mess. Is it fully updated?
Old Apr 4, 2013 | 03:57 PM
Yeah I pushed 2008 mr beta maps and I just downloaded manger 2.0 what version of software should be in the cobb
pandaevoz
Mar 28, 2017 06:56 PM
cnote2
Cobb AccessPORT
Jun 13, 2016 04:35 PM
Tribal
Sep 5, 2013 06:04 PM
evofan_08
Oct 29, 2012 03:40 AM
pltek
11
Dec 23, 2011 01:08 PM
