2014 gsr , w/b issues with ap
Old Feb 2, 2015 | 11:58 AM
dtmevox's Avatar
so i wired my inovate w/b 02 sensor into the rear 02 port the other day , the inovate gauge reads fine but i cant get the a/p to report the same numbers i see on the gauge ?
i grounded the 02 harness as descibed in all the threads ive found on it , but still cant get it right , im using the aem setting on the ap . but still no dice , and im getting a front 02 ground circut code as well , anyone else have this issue ? oh and my rear 02 wire colors are different than what everybody else seems to have ? any input would be great
Old Feb 3, 2015 | 10:32 AM
ikt's Avatar
ikt
the wire colors were different on my 2013 as well. Sounds like you tapped the wrong wire. I know mine was all messed up following that guide. Do you have a multimeter? you can use that to figure out which wire is ground
Old Feb 5, 2015 | 03:31 AM
dtmevox's Avatar
yep i have a meter , but what wire am i grounding , there should be 2 , the heater and the ecu ? , i just followed the 02 side wires i figured they should be the same . lol oh mitsu why do you mess with us ! . so what am i testing for , to find the right ground ..
Old Feb 12, 2015 | 08:03 AM
Heymybigfish's Avatar
hi i'm new here, so if my post is completely off base, just disregard and label as noob.
from what i understand and have read so far, using the rear 02 sensor for the WB doesn't read properly for w/e reason. i'm just guessing you're using the wrong sensor?
Old Feb 22, 2015 | 06:00 AM
dtmevox's Avatar
no im not using the wrong sensor ,, ill call noob on your reply
20redfire03
Mar 14, 2016 08:23 PM
TxFAkuma
Jun 12, 2015 11:35 AM
edwinisdumb15
West Region
Jul 16, 2014 10:14 AM
Kracka
South Region
Feb 2, 2014 07:28 PM
BoostedMKIV
North Texas Evo Club (NTEC)
Jan 22, 2014 07:41 AM
