Can't boost above 19PSI - Target boost Pro-tune 27PSI(log attached)
3 Attachment(s)
Hi Guys,
I have been trying everything to get my pro-tuned Evo X back to target boost of 27.5 PSI, only able to reach 19PSI. Boost leak tested good, smoke test tested good, no leaks. Attached are logs, 3rd gear pull to red-line with UEGO on Cobb ATR software. Any advice is much appreciated! {thumbup} Mods: EF2.5 w turbosmart IWG, ETS UICP&LICP, ETS V2 exhaust w Cobb HFC, Grimmspeed 3port, Drivenfab catch-can, FIC1000cc, DW65c Fuelpump, UEGO AFR. |
Check your wastegate to see if its opening and closing properly as well as the rod adjustment
I found a minor turbo-exhaust manifold gasket leak, that's likely why I can't get the boost up.
Pressure checked the turbosmart wastegate actuator and it's good. |
Looks like your running wastegate pressure. Double check to make sure your vacuum hoses on the 3 port are not crossed. Seen it before.
| All times are GMT -7. The time now is 09:45 PM. |
