Can't boost above 19PSI - Target boost Pro-tune 27PSI(log attached)
Old Sep 8, 2015 | 08:34 PM
Merlion's Avatar
Hi Guys,
I have been trying everything to get my pro-tuned Evo X back to target boost of 27.5 PSI, only able to reach 19PSI.
Boost leak tested good, smoke test tested good, no leaks.
Attached are logs, 3rd gear pull to red-line with UEGO on Cobb ATR software.
Any advice is much appreciated!
Mods:
EF2.5 w turbosmart IWG, ETS UICP&LICP, ETS V2 exhaust w Cobb HFC, Grimmspeed 3port, Drivenfab catch-can, FIC1000cc, DW65c Fuelpump, UEGO AFR.
Old Sep 9, 2015 | 04:35 AM
evo8426's Avatar
Check your wastegate to see if its opening and closing properly as well as the rod adjustment
Old Sep 9, 2015 | 08:43 AM
Merlion's Avatar
I found a minor turbo-exhaust manifold gasket leak, that's likely why I can't get the boost up.
Pressure checked the turbosmart wastegate actuator and it's good.
Old Dec 2, 2015 | 07:33 AM
Spazpilot's Avatar
Looks like your running wastegate pressure. Double check to make sure your vacuum hoses on the 3 port are not crossed. Seen it before.
LaXGSR
135
May 24, 2012 08:50 AM
enash99
Jul 11, 2011 04:10 AM
ouminan
Aug 8, 2008 04:00 PM
Jordanz3
10
Aug 25, 2007 04:24 PM
UndieStainz
AEM EMS
16
Sep 28, 2006 03:50 AM
