Do I have a boost leak? log graphs attached...
Old Aug 8, 2008 | 03:13 PM
ouminan's Avatar
Question Do I have a boost leak? log graphs attached...
I suspect that I do as I *think* I hear a whistling noise when I'm boosting, but I do have a slightly different air filter on at the moment so I wanted to make sure that it's not just "psi drop" or something related to a new intercooler.
WGDC settings are the same between the two logs.
Stock IC:
Aftermarket IC:
Old Aug 8, 2008 | 04:00 PM
bboypuertoroc's Avatar
Veteran: Army
Did you do a boost leak test? That would be the easiest way to find out.
