1st timer 12.83 @109.7
Old Nov 4, 2004 | 10:38 AM
ryan t's Avatar
my 60' sucks at 1.8. front wheels spinning and they chirp at 1-2 ,2-3 shifts what can help wheel spin i know this thing should be much quicker with my mph im getting.boost was at 19lbs im going back in a few weeks with race gas and 22lbs any advice on launch and wheelspin, i tried dump and slipping it
Old Nov 4, 2004 | 10:45 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
you need to get a better tire combo/suspension setup or something if you are honestly chirping your tires from 2-3....i spin all through 1st and part of 2nd and run mid 11s at 123 mph and still don't chirp into 3rd....lol
Old Nov 4, 2004 | 11:03 AM
Ev0ikon's Avatar
Nah, it's because that track was cold and didn't prep worth a crap :}
Old Nov 4, 2004 | 11:07 AM
evodave's Avatar
i also run on a horrible track around here (dragway 42) and the last few times we ran it was about 45-50 degrees
Old Nov 4, 2004 | 11:08 AM
DrEvo's Avatar
Ditto on the 1st gear spin!! Once you start putting down good power, a good tire/suspention combo is definitely needed. I have an in car video of the camera facing the passenger side rear and you can see the *** end of the evo getting sideways from the launch, lol . If you are interested I can post it up. My 1st gear pretty much spins out. Next time I am going to try and lower my tire pressure see if it helps.
Good luck with the lower ETs. Its just a matter of getting more runs under your belt and you'll start gettting the hang of it.
Old Nov 4, 2004 | 11:15 AM
DRFTKNGG's Avatar
Evo reflashing
I would be intrested in seeing your timing and fuel mapping. Maybe we can compare notes. I just did a reflash and I am constantly adjusting the maps. I live in Orlando, so if this is cool, just e-mail me. Do you data log? I have an almost stock evo. Profec-b, no cat, K&N drop in, forge motorsports BOV, 110 fuel, 22lbs, I ran a 12.20 @ 106mph. Max timing was 15deg. My 60's are 1.6 and 1.7 consistantly. I would like to get into the 11's with the stock exhaust and airbox. I am doing some port work on an extra 16g and I just purchased a head that I will be porting, larger valves, 272 cams. So, let me know if we can compare data logging. I am always willing to help out my fellow Evo owners!
Ruben
ASE Master Tech
Mortgage Broker
Old Nov 4, 2004 | 11:18 AM
Rez90's Avatar
What suspension setup are you running
Old Nov 4, 2004 | 11:19 AM
fimotorsports's Avatar
i ran a 12.3 at 108 in 40 degree weather with all season tires... 1.6 60 foot, car hooked up perfectly. I think it's the tires and possibly the track, but lower your tire pressure that should help out a lot.
Old Nov 4, 2004 | 11:25 AM
ryan t's Avatar
i lowered front to 20lbs and back up to 34lbs, didnt help a whole lot, and yes i have crappy goodyear tires
Old Nov 4, 2004 | 11:37 AM
evodave's Avatar
titanium strut bars, tein ra coilovers (aluminum bodied) 14 out of 16 setting stiff , 245 40 17 conti sport 2 tires (25psi f/b) on 5zigen 17X9 rims with 35mm offset ....still haven't gotten a alignment
Old Nov 4, 2004 | 11:38 AM
VTECH8TR's Avatar
titanium strut bars, tein ra coilovers (aluminum bodied) , 245 40 17 conti sport 2 tires on 5zigen 17X9 rims with 35mm offset ....still haven't gotten a alignment
Dave,
The alignment will make a world of a difference.
Old Nov 4, 2004 | 01:13 PM
plokivos's Avatar
Yeh, those goodyears don't help that much either.
Old Nov 4, 2004 | 01:16 PM
stevEVO8's Avatar
Ruben
ASE Master Tech
Mortgage Broker
Yo what's up ruben; Im the guy you met at the gas station with the blue evo.
Old Nov 4, 2004 | 01:52 PM
EvilDylan's Avatar
you ran the EXACT time i ran at steele
what are the odds?
i ran 12.83@109 with a 1.8 60 foot.
Old Nov 4, 2004 | 02:59 PM
VTECH8TR's Avatar
Steve,
You in Orlando right?
