05 Evo 12.41@112.03
My friend has an 05 with tbe, 660 injectors, pump, safc, bc@20psi@ redline and has to pull about 25% out with the safc and his seems to run real good. Traps 114 all day. I think its the extra boost and timing he is getting with taking out so much fuel. I just picked up a set of hks 264s and I think Ill do some injectors and pump at the same time I install the cams. Hoping for 115-116 traps with this setup. High 11s should come with this setup.
Are these mphs based on race gas like your current 112? I assume they are...
I am comparing race gas to race gas. thats the only way I will race it at the track.
My srt was no joke. that thing suprised alot of people. On the fly it was unstoppable. I beat numerous cars that trapped mid 120s. I had alot of money into it and it looked just as bad ***, as it performed. ill post some pics of it. I had a 60trim on it at 23psi pump gas when it hit 420whp. never had a chance to take it back to the dyno on race gas and 26psi. Thats when it really woke up. 475whp is my guess.
Here is the link to the pics
http://www.srtforums.com/forums/show...ghlight=reborn
motor is just as strong as the 4g. Internals are good for 500whp and the block is good for whatever you can throw at it. All forged internals from the factory but seem to let loose about 500-550 whp. He needs to tune it to low 11s for afr on pump gas and it will last forever if he doesnt get greety. 420whp is easy with this turbo if tune is right and you have supporting mods. Its easier to made 425-450 whp with a 50 trim on these cars. Srts love 50 trims for some reason. But you have more potential at higher boost levels with the 60trim. If he needs any advice have him hit me up.
